Results 1 to 7 of 7
Thread: Tune
    VY II SS
    Jun 2005
    Default Tune
    I'm interested in getting a tune for my ss, im just curious as to how much it will cost and which was is the best to go. Mafless or a Ls1 edit? Do you really get more power out of a mafless tune or is that just a rumor?
    So far all i have is catback 2.5inch exhaust and removed the rear muffler which i think i want to put a hotdog or something on it to get rid of the drone, ive also got 3.9 diff ratio to get a bit more get up and go from low revs.
    Any input appreciated!
    Thanks!
    minux's Avatar
    minux is offline Infidel Bear
    300rwkw FG G6ET/2011 Sti Spec R Hatch
    Mini Putt 2 Champion!
    Feb 2005
    Hard to tell you where to go when we dont know where you live!!!!
    Mafless vs non mafless...well at one stage the mafless was better, without running an OTRCAI, now its even from what i understand. Unless you want to run an OTRCAI mafless tune is pointless.
    "Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind."
    - Theodor Seuss Geisel
    VY II SS
    Jun 2005
    I'm in Sydney on the northern beaches, i wouldnt mind getting an OTRCAI, but i guess whichever of the tunes is cheaper would be the one id go for, i dont really want to fork out big bucks for a tune!
    MY 9.5 SSV Sportswagon M6 & 08 prado D4D GXL M6
    Nov 2005
    Bushfield, Vic
    Yep as minux said you need an otr intake before mafless would be better then maf tune. I went a maf tune on mine and made 236rwkw (191 standard) because i wanted to keep the standard intake because the car's still under warranty. I also got a ripshifter fitted (good thing that).
    [CENTER][URL="http://forums.justcommodores.com.au/showthread.php?p=490264#post490264"]
    vp v6 commodore executive
    Aug 2006
    south island newzealand
    least if you go maffles it one less exspensive part that can stuff out apart from that either should get you smiling
    minux's Avatar
    Feb 2005
    Quote Originally Posted by Solid_snake01 View Post
    I'd just go a standard tune, around $800 these days depending on where you go. Seeing as you are ins ydney id go to Marranos Enhancement Division - LS1/LS2/L76/L98 Performance Specialists the guys there are awesome, i just wish i had the time to drive up there to get some work done.
    VYClubby's Avatar
    VYClubby is offline Proud Clubby Owner
    294rwkw Oztrack Tuned 220 cam
    Nov 2006
    Oztracktuning does mafless tunes for $500 for a dual spark tune. I have one in my VY Clubsport as well as an OTR, and it made 248.8rwkw on the SAS dyno. The car had a maf tune by Marranos before that and made 233rwkw on the same dyno. I have found the car has better throttle response and more midrange with the mafless tune. If you have the cash go with an OTR as well the induction sound is truly awesome!
  1. Tune for C.O.M.E cam
    By Drew4692 in forum V8 Development and Modification
    Last Post: 13-03-2007, 05:32 PM
  2. Tune up!
    By emmtee83 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-06-2006, 04:39 PM
  3. On the tune!
    By fitykemp in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 14-01-2006, 10:37 PM
  4. tune up
    By byt in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-09-2005, 03:25 PM
  5. Tune Up
    By adsVN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-04-2004, 03:33 PM
