+ Reply to Thread
Results 1 to 7 of 7
Thread: S2 VY O2 Sensors
    1999 Honda Accord Wagon 2.3 VTEC
    Oct 2005
    Wellington, New Zealand (Yes i know yet another KIWI)
    Default S2 VY O2 Sensors
    My V6 S2 VY has done 61000+kms and i would like to check the o2 sensors to see what sort of condition they are in.
    Can anyone advise me where they are located and how to remove them. Any pics would be helpful thanks.
    VT Berlina 07's Avatar
    VT Berlina 07 is offline 15.37 @ 147 KPH VT Berlina 07 Executive
    96 EF2 Futura I6 Auto
    Apr 2007
    Sydney, NSW
    hi, they are on the extractors just before the cat. open the bonnet and follow the headers down towards the cat, you cant miss them, they are a big sensor that plugs into the headers. since this is a V6 you have 2
    96 EF2 Futura I6 Auto Sedan Superlows Front/Rear with Monroe GT Sport's, EL XR Front, 16" Tickford Wheels with 225/50 Wanlis, 5% Tint, Sony Headunit/ 6 1/2" 190w Speaker's, Fram Air Filter/XR6T Snorkle, Pacemaker 4499's/Hi Flow Cat/2.5 inch Redback, 4.11's/LSD 15.37 @ 147 KPH
    impulsesv6's Avatar
    impulsesv6 is offline Alloytec Garage impulsesv6 Executive
    A quick Alloytec
    Dec 2006
    brisbane, QUEENSLAND
    Raptorsc's Avatar
    Raptorsc is offline RAPTR6 Raptorsc Executive
    Hilux 4.0 V6 SC 270kw
    Jul 2006
    Mackay Qld Australia
    On VY just the one pair only, should be in perfect order at 61 000km. Is the fuel economy not good or just having a look to be sure they are good?
    Raptor Superchargers - Boosting S1/S2 3800's, Ecotec's, Alloytec's and 304's
    Not_An_Abba_Fan's Avatar
    Not_An_Abba_Fan is offline Exhaust Guru Not_An_Abba_Fan W427 Not_An_Abba_Fan W427 Not_An_Abba_Fan W427 Not_An_Abba_Fan W427
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    You won't be able to see if they are any good or not. The sensor part is inside the metal fluted section. There is no visible sign that they are buggered, they are not like a spark plug. Colour may tell you how the engine is running but not if the sensors are working. You can test them if you have a multi meter.
    http://www.facebook.com/?ref=home#!/...21292461287296
    Oct 2005
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    You need to take the car for a hard drive to get them hot, and keeping the revs up around 2000 rpm, test the signal wire, the voltage should be fluctuating rapidly from around 0v to 1v. Clamping off the fuel return line slightly raises fuel pressure and makes the engine run rich, this should send the volts up around 0.8v. unplugging an injector will make it run lean and the voltage should drop to about 0.2v. The O2 sensor will be a 4 wire , two of those are earth, one is the heater wire and the other is the signal. The heater wire will have a constant voltage. I think the signal wire could be pink on the VY.
+ Reply to Thread
  1. O2 Sensors
    By yeah,yeah in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-05-2006, 06:52 PM
  2. what do i do with sensors with air pod in
    By crainy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-08-2005, 07:58 PM
  3. v6 and v8 o2 sensors
    By aero19 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-08-2005, 04:37 PM
  4. sensors
    By CAFA_TF in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 04-04-2005, 08:20 AM
  5. O2 sensors...
    By MY_95_VS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-03-2005, 04:58 PM
