+ Reply to Thread
Results 1 to 16 of 16
Thread: SS Cold Air Induction
    VY 5.7 A4 SS
    Dec 2006
    Default SS Cold Air Induction
    I have recently thought about tinkering with my baby. Small at first i was thinking about cold air induction. Having a look at the air box, it does have a decent intake directed at the head light.
    I was speaking to a guy and he was recomending a SS inductions kit, (see link) But for the kit and a K&N filter im looking at $530. I thought i better ask the around and get some feedback, weather its actually worth it?
    Im pretty new at all this so any help will be appreciated.
    Link to SS inductions kit.
    Holden VY V8 5.7 GenIII SS Induction Kit
    Oh btw i have a VY SS 5.7L
    Thanks
    VZ HSVDT
    Aug 2007
    melbourne s.e suburbs
    def a good upgrade once u got exhaust and a set of headers to maximise the performance gains.. heard alot about the Vy kits .. went to a shop were the guy had 1 in his Vy ss ute looks and sounds nice .. depending if u wana go the pod filter set up or just with a K&n Pannel or BMc pannel filter ...
    dyno figures reckon u can get a 12kw increase
    u should try looking on Ebay as they are abit cheaper...
    good luck
    VR,SS manual
    Sep 2007
    Auckland NZ
    I did a cold air induction about 6months ago along with remapping.It made a noticable difference.I've not yet dynod but have recently added a man T5 trans and its starting to be fun to drive.
    VYClubby's Avatar
    VYClubby is offline Proud Clubby Owner VYClubby Executive
    294rwkw Oztrack Tuned 220 cam
    Nov 2006
    Commonly know as an SS REDUCTIONS kit. They are made of pretty thin plastic tubing that actually sucks in under WOT reducing the diametre of the intake! You are better off going with the old reliable Monaro Cold Air Intake and 2 hole mod on the airbox. You can get the parts from Holden and with a K and N filter the whole thing would cost less than $200. I did it to my Clubby before my mafless tune and it worked a treat. Just remember on the SS Reductions box it says "up to 12rwkw" so the gain could be just 1!
    vy ss commodore 5.7ltr
    Jul 2006
    hey vy clubby, is this monaro kit for the gen3's? (might sound like a stupid question, but i know they had v6's and i had a v6s/c ecotec cai on my vr v6, with a k+n airfilter worked a treat on a stock v6)
    2000 VT
    Sep 2007
    Central coast
    My mate has a VY SSZ 5.7ltr and has just bought an SS Inductions 'Growler' kit... The gain is noticable, especially at high RPM and the sound is just amazing.
    It does has a full twin 2.5in exhaust also. I love it when he boots it on the straights.. sounds so aggresive!
    minux's Avatar
    minux is offline Infidel Bear minux W427 minux W427 minux W427 minux W427 minux W427 minux W427 minux W427 minux W427
    300rwkw FG G6ET/2011 Sti Spec R Hatch
    Mini Putt 2 Champion!
    Feb 2005
    Quote Originally Posted by S7YL1N View Post
    Your mates SS would have to be the first ever car that has improved. I tried the SS reduction kit 3-4 different times on a dyno and it made NO difference at all.
    You are best saving your $$$ and buying an OTRCAI setup, get a maf version, and a tune. Simple
    "Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind."
    - Theodor Seuss Geisel
    VY2 Clubsport
    Aug 2007
    Hocking, WA
    yep, mcai for me works a treat on my VY2 clubby...thought about the other after market kits (SS & KN pod) but all i needed to do was spend less than $30 to get near the same sound in WOT, without the excessive sucking noise of the pod...she is more responsive on the throttle.... performance increase wise, well i don't know only a dyno would tell the picture but probably not much over standard 285kw as i haven't changed the factory HSV cat back yet...
    OTR for sure if u want to spend the $$$ on it, but for me i'm sticking with the GTS air box/pipe & mcai...
    minux have u got a maf tune or mafless, if it's MAF, how has ur driveability increased...
    VY S PAC 5 speed
    Apr 2007
    WA
    Quote Originally Posted by minux View Post
    You wouldnt really notice a SS induction kit on a Dyno though
    BANKS's Avatar
    BANKS is offline DW I'm a Spray Painter! BANKS Monaro BANKS Monaro
    VZ SSZ Ute
    Aug 2007
    Gold Coast QLD
    so where did they get their supposed 12rwkw gain from then? a twin blown big block?
    vt1538's Avatar
    vt1538 is offline 455rwhp LS3 vt1538 Statesman
    VY SS S2 11.284@125mph
    Sep 2005
    The Dead Centre
    I have done a heap of logging on my car and a few others with a few different intakes. The two hole mod lowered the intake temps a few degrees more than the standard air box. Still seeing IAT,s around 45 deg on a 30 degree day. A CSV OTRCAI I fitted to a VY Sandman was much better but still sees IAT's around 35 deg at the same ambient temps.
    The most disappointing was a shielded pod set up on a VYSV8 that showed no improvement over stock. I cannot remember what brand this was but I will post it when I see the car again. These were all tested at highway speeds with the same ambient conditions.
    VY2 Clubsport
    Aug 2007
    Hocking, WA
    i've made an PVC pipe extension, coated in heat temp black spray paint, on my GTS air box (2 hole) to draw cold air from beneath the left front headlight (behind the high beam globe). after driving for about an hour, removed the radiator shroud and felt the make shift piping, must say it was not hot, like the MAF pipe, to touch, it was actually very luke warm to cool....
    i'm stickin to my air box, bugger the pods....
    VX II SS Ex Chaser V8
    Jul 2005
    Why are these bought pods so darn expensive ? $300 plus for injection molded plastic.
    Peter
    VYClubby's Avatar
    Nov 2006
    Quote Originally Posted by ozengines View Post
    Peter
    I think they are a bit ricer, so people will pay alot because a pod is "fully sic mate", even though they make no more gain than the trusty 2 hole mod. Your better of saving the money and getting a catback exhaust, there would be more gains that way.
  15. #15
    VYClubby's Avatar
    Nov 2006
    Quote Originally Posted by cpbait View Post
    Yes mate they are on the Gen 3's
  16. #16
    VYClubby's Avatar
    Nov 2006
    I think that alot of people get conned by the louder induction noise and they think that it makes more power as it sounds louder
+ Reply to Thread
  1. cold air induction
    By badaz in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-09-2007, 07:50 PM
  2. best cold air induction for an ls1
    By TysonSS in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-04-2007, 06:24 PM
  3. what is best cold air induction for a v6
    By agrocm in forum V6 Development And Modification
    Last Post: 28-02-2007, 08:55 PM
  4. Cold Air Induction VP v8
    By vp clubby in forum V8 Development and Modification
    Last Post: 28-03-2006, 04:48 PM
  5. cold air induction
    By mistermeena in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-10-2005, 11:57 PM
