+ Reply to Thread
Results 1 to 12 of 12
Thread: New Mag wheel not fitting
    The Windsurfing VY Wagon's Avatar
    The Windsurfing VY Wagon is offline Donating Member The Windsurfing VY Wagon Executive
    VY S2 04 S/W
    Oct 2006
    Cairns, QLD
    Default New Mag wheel not fitting
    Hey there all,
    Quick question, has any body had this problem before?
    I was putitng on my new 19" wheels to day starting with the front.
    The right hand was sweet and bolted right on and freely spun but the left hand is rubbing on the bottom of the strut tower.
    Looking at both wheels etc it looks that the whole left hand hub etc is sitting much further in than the right.
    Any ideas why this would be or how to fix it?
    I have had to put my 18" back on for now so I look forward to any comments.
    Windsurfing.....
    This is what you call a real sports wagon, BOUY!!!
    AirStrike's Avatar
    AirStrike is offline Site Administrator AirStrike W427 AirStrike W427 AirStrike W427 AirStrike W427
    2009 G6ET
    Jul 2003
    VY S2 04 S/W
    Oct 2006
    Cairns, QLD
    Sure are the Holden 19" Rims.
    It's not the wheels as I have worked out but seems to be the whole hub etc is sitting in alot closer????
    Windsurfiing.....
    Raptorsc's Avatar
    Raptorsc is offline RAPTR6 Raptorsc Executive
    Hilux 4.0 V6 SC 270kw
    Jul 2006
    Mackay Qld Australia
    What sort of 18s are the ones you want to take of the car?
    Raptor Superchargers - Boosting S1/S2 3800's, Ecotec's, Alloytec's and 304's
    VY S2 04 S/W
    Oct 2006
    Cairns, QLD
    Hey there Raptor,
    Here is a pic of them for ya.
    I have not really thought about what I want for them to tell you the truth but can work some thing out for sure.
    What the story is there are two brand new wheels & tyres for the rear and the fronts are used but in exc condition with 75% tread left.
    There is also one spare with 75% tread left but the wheel is dented due to a big rock passing under the wheel thanks to a truck spitting it out at me.
    Since your just down the road freight would be easy.
    BTW I would love one of your systems for my VY SII but, well, you know money, money, money but in saying that let me know if there is some thing you would like to work out, that I can't afford of cause.......
    Windsurfing.....
    Attached Thumbnails Attached Thumbnails New Mag wheel not fitting-070-copy.jpg
    VY Executive 2003
    Sep 2007
    i wouldnt mind a set of mags like that
    im looking around for some for my VY 2003
    fmlycar's Avatar
    fmlycar is offline 6appeal fmlycar Executive
    308rwkw 180sx
    Oct 2006
    Alice Springs
    Are they a staggered set? You may have a little wider rears and that's maybe why one won't fit. It shouldn't be the hub if you didn't have any issues with your 18's. Is they profile the same on all the tires?
    When you see a car that's BLOWN it's refering to the budget.
    VY S2 04 S/W
    Oct 2006
    Cairns, QLD
    I think I might have a bent shock to tell you the truth but she still drives fine which is odd but I will get her in to Pedders for a look and see what they say.....
    Windsurfing.....
    VY Executive 2003
    Sep 2007
    vn/vp Speedway Street Sedan
    Sep 2005
    Check that your front strut is not bent. ( that is the cylinder that the shocky inser fits into).They usually bend just above where the stub assy is welded to it.
    Also check that the lower control arm or radius rod is not slightly bent or stretched.
    I would try swapping one of the other rims that fit onto it as well. maybe they accidently gave you one wheel with an incorrect offset?
    hsv_punk's Avatar
    hsv_punk is offline I Just Want One hsv_punk Executive
    VYII Berlina V6
    Jan 2005
    VIC
    Different offset front to back? I know some wheels come with a different offset on the back when compared to the front. Just an idea....
    ..::HSV Punk::..
    VZ Clubsport
    Oct 2007
    Busselton, WA
    Ive nearley got the same problem, i got a gap no thicker than a $2 coin, I got told that the only way i am going to fix this is to get aftermarket strut tower.
+ Reply to Thread
  1. Fitting streering wheel satin insert
    By v6vy in forum VY Holden Commodore (2002 - 2004)
    Last Post: 27-12-2007, 08:08 PM
  2. Fitting Vt Steering Wheel Air Bag
    By KPCH53 in forum Electrical Wiring / Questions
    Last Post: 01-09-2006, 01:37 PM
  3. Fitting LPG
    By The VHK in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 01-03-2006, 06:47 AM
  4. Your thoughts on replacing steering wheel with airbag to a MOMO wheel....
    By *VOLATILE* in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-02-2006, 08:36 AM
  5. Fitting ABS
    By HQ_Kid in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-01-2005, 10:46 AM
