+ Reply to Thread
Results 1 to 3 of 3
Thread: Removing interior door trim
    VY Berlina
    Sep 2007
    Smile Removing interior door trim
    Gday guys and gals
    Bit of a noob question I know, but wondering if you can give me an idea of how to remove the Interior door trim. I've undone the 8 or so screws around outside of trim and also removed interior door opener, but still can't get the bloody thing off.
    Seems to be stuck behind the cloth insert in the door trim.
    Reason being I want to sound proof inside door and replace factory speakers.
    Also seems the window guide is rattling around and driving me mad.
    PS I;ve done a search but still can't find what I'm after.
    Thanks in advance.
    VU manual
    Dec 2005
    what ya gotta do mate, is remove the red tab from the door lock, just pry it out with a pick or small sharp screwdriver. once it pops out, lift out the lock and there is a screw behind it.
    also remove the interior side mirror cover, they just clip on so pull it off by hand. there is also another screw to remove once you take out the door opener if you havent noticed that one.
    then what ya wanna do (if you cant see anymore screws holding it on) is lift the trim upwards and then you should be right from there.
    VY Berlina
    Sep 2007
    Cheers Adam. You're a champion
+ Reply to Thread
  1. Removing VT/VX door trim
    By Julie in forum Holden Commodore How-To's
    Last Post: 13-10-2011, 09:35 PM
  2. Removing Door Trim
    By funnyfarmer in forum Car Audio
    Last Post: 21-08-2008, 03:12 PM
  3. Removing door trim
    By Noy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-12-2006, 03:01 PM
  4. Removing interior roof trim?
    By ncielens in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 19-11-2006, 08:04 PM
  5. Removing door trim
    By smyth in forum VY Holden Commodore (2002 - 2004)
    Last Post: 26-02-2006, 12:55 PM
