+ Reply to Thread
Results 1 to 17 of 17
Thread: lowering
    VY Acclaim Wagon And VX SS
    Jan 2007
    Sanctuary Point
    Default lowering
    I am going to lower my wagon 50mm from standard and i want to know if i have to get shortend shocks or will the standard shocks be fine.And is it very difficult to do.I,ve done front springs before on my old falcon,never done the rear before.
    Not_An_Abba_Fan's Avatar
    Not_An_Abba_Fan is online now Exhaust Guru Not_An_Abba_Fan W427 Not_An_Abba_Fan W427 Not_An_Abba_Fan W427 Not_An_Abba_Fan W427
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    The standard shocks will work fine, but on the rear it is advisable to use shortened shocks to trap the springs.
    http://www.facebook.com/?ref=home#!/...21292461287296
    Jan 2007
    Sanctuary Point
    VYClubby's Avatar
    VYClubby is offline Proud Clubby Owner VYClubby Executive
    294rwkw Oztrack Tuned 220 cam
    Nov 2006
    Actually the rear shocks in a wagon are shorter than a sedan so they are fine. Alot of people intsall wagon shocks in their sedans. Also does an Acclaim have FE2? If so that is fine also. As for how hard it is to do. I do mine in 2 hours in my driveway. I change springs for the drags. On the Street Commodores website in the how to section I have made a thread including pics on how to do it.
    SweetWagon's Avatar
    SweetWagon is offline booosted SweetWagon Calais
    VS Berlina Wagon Supercharged
    Jan 2006
    Springwood NSW
    Also pretty sure they dont make a shortened shock for IRS.
    Power is measured in DECIBEL
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Wagon shocks are shorter than a sedan but when lowering you are still going lower than the standard spring so there is still the risk that they will pop out. It all depends on how low you go though.
    Quote Originally Posted by vn6pwr View Post
    They do, and I can get them.
    Jan 2007
    Sanctuary Point
    Quote Originally Posted by VYClubby View Post
    Thanks for the help.pretty sure my acclaim doesn,t have FE2.
    Jan 2007
    Sanctuary Point
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Roughly how much are the shocks going to cost,and whats a good brand?
    VYClubby's Avatar
    Nov 2006
    The wagon springs are fine for Superlows. What springs are you fitting? Seeing as you said 50mm I am guessing Superlows so it will be fine.
    Jan 2007
    Sanctuary Point
    yeah kings superlows.
    VYClubby's Avatar
    Nov 2006
    Jan 2007
    Sanctuary Point
    Your shocks willl definately be o.k then. Even the suspension places would leave them as they are.
    sounds good to me i will leave the standard ones in for now then.
    VN Calais 5.0L
    Feb 2006
    Do the same rules apply for a sedan - Calais series 2? Or is it adisable to replace shocks at same time?
    What is the average lifespan of a set of shocks? my car has 90k on it.
    davey g-force's Avatar
    davey g-force is offline I'm a sceptic... davey g-force Calais
    Phantom MY09 VE SSV A6 & Holden Cruze CDX M5
    Sep 2005
    "...the winner is..."
    Quote Originally Posted by daves8 View Post
    You don't need to replace the shocks, however at 90K the factory ones are getting a little tired and it would be good to replace them if you can afford it.
    Quote Originally Posted by Jeremy Clarkson
    Humankind used to celebrate the wise and the rich. Now, we look up to the stupid and the fat. We tune into The X Factor to watch people exhibiting their uselessness, and we like reality TV shows because everyone's daft. Clever people are mocked. Rich people are hated. And cars, as the most outward signs of someone's wealth, are bound to suffer as a result.
  15. #15
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    According to most shock manufacturers, the effective life of a shock is around 40 000kms, so they would say replace them.
  16. #16
    2005 VZ Alloytec 175 wagon
    Feb 2010
    Portland VIC
    i have been told that on the vz's that they have camber adjustment. true or false? i have a wgon too and want to lower it but am worried that the tyres will scrub out far too quickly as i have 19's on it. i have been looking at pedders suspension for it and was quoted around 700 for it to be fitted but not sure what was actually getting done. is this a reasonable quote?
  17. #17
    VY executive ute s1
    Jan 2009
    Short shocks are a good idea, especially if you use king springs. Monroe make a great set of short shocks and struts for ute, sedan and wagon. They take some of the sharpness out of the king springs ride and up the handling tenfold
    The characteristics of the monroe short struts for the front will help with the uber common occurance of the bearings failing as they have different bump and rebound to the normal OEM shocks. for the shocks and struts alone your looking at just under 400 delievered to your house, more if you go throught the workshops
    The difference is shocks which are non-adjustable are made to travel certain distances with a certain springload. OEM shocks work best at there original ride height with the original springs, and ofcourse shorter shocks work best in low situations.
    Easy way to put it
    OEM shocks, Low Spring: Shock moves between 50 to 100% of its original travel, Thus only giving half the effect of its design (bump rebound settings etc)
    Low Shocks, Low Springs: Shock moves its entire 100% of travel, thus using the full effect of its deisgn (bump rebound settings etc)
+ Reply to Thread
  1. Lowering
    By watson01 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-03-2007, 04:51 PM
  2. lowering my vy
    By fluxxx in forum VY Holden Commodore (2002 - 2004)
    Last Post: 09-10-2006, 10:53 PM
  3. lowering a VT
    By cameron4518 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-11-2005, 10:27 PM
  4. lowering car
    By Moe in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-11-2005, 10:29 PM
  5. lowering??
    By noideea in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-09-2005, 08:17 PM
