+ Reply to Thread
Results 1 to 5 of 5
Thread: Air con - and the Big click
    Holden Calais supercharged V6
    Jun 2005
    Default Air con - and the Big click
    I have realized , when ever i turn the aircon on there is a loud click , coming from engine bay. now i have heard this on some other vy-s aswell. it was the same with my VX....
    However there is no clicking on VS models..etc... What this clicking cause by?! can i remove it...?!1
    Also I noticed , I loose a bit of power when the aircon is on.. and when the car is idling at lights i can hear some sort of buzzing noise in series of repts , but when it is in neutral its gone ..Does anyone else have the same problem?!!
    thank
    oh and in my previous tread, oil in radiator i had the radiator and engine pressure tested and the result were negative . so the source of oil in my radio tar is still unknown...
    vp v6 commodore executive
    Aug 2006
    south island newzealand
    Jun 2005
    Quote Originally Posted by spanners View Post
    ide say the click is the clutch on the aircon compressor engaginging
    in that case i should be able to replace the clutch with some high quality one..?!!! or just simply change the air con.. after all holden air cons are quite noisy..
    08 VE SS-V 6.0Lt V8 SEDAN
    Mar 2006
    I wouldnt bother changing anything unless the A/C is not working or doesnt put out enough cold air. The load clicking is normal as mentioned above. Just the Clutch kicking in. As for power loss, well all cars will lose power when the A/C is on, because it is directly driven by the fan belt which will put more strain on the engine, therefore providing less power for driving.
    Jun 2005
    Quote Originally Posted by oztech007 View Post
    thanks for the advice
+ Reply to Thread
  1. Is it normal for the ECU to 'click'
    By MyVPIsFasterThanYourVP in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-01-2007, 04:56 PM
  2. "CLICK CLICK" in VTII
    By tdog in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-05-2006, 10:12 PM
  3. Click Sound in ECU??
    By Ronaldw in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 16-12-2005, 10:59 AM
  4. hot chicks!!! click here
    By goldvn in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-08-2005, 05:34 PM
  5. Not starting.. click, click, flash, click
    By FoxyKunt in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-06-2005, 06:35 PM
