Im also interested in swapping auto to manual, and found out your looking at over 3k to swap a six speed in.
Hi there,
Just wondering if any one has done a manual conversion on their commodore
if so can you put a six speed in a 03 VY Calais 3.8L Ecotech i know you can put a five speed in but can you put a six speed in.
I to have also been tempted to change mine to a manual seams to be way to expensive though $2500. Why don't you buy a car with a manual transmission when you are ready for your next one.
Don't drink and drive you might spill some
My Ride:http://forums.justcommodores.com.au/vt-vx-vu-wh-v2/54055-first-car-vt-berlina.html
did the VY come out with the V6 6Speed though? or was it only the 5?
Youd be looking at around 3 easy....
Theres alot to add and remove. Not an easy task.
aZk.
everything is possible with money, you never know, a ecotec 5-speed bellhousing could bolt upto the vz 6 speed box,
wont know until you expirment
EASTERN CREEK JCNSW 2009
Originally Posted by Commydoor
I think holden used the same auto box vy/vz so maby you'd be lucky with the manual being the same. I have a feeling though the vy box was a getrag and the vz a asian box or something like that?
Good luck with it![]()
I know that the manual box in VE SV6's is a BMW built trans not too sure about the manual trans box on VZ's/VY's.
Why don't you try this mob:
Mal Wood Automotive
Im sure if anyone would know if its feasible, it would be these blokes.
