They don't make them yet, i run phillips in mine and they're a bit brighter than standard.
I want to change the standard H9 and H11 globes (yellow light for the blue/whitw light}in my Calais headlights (higher luxury set up), I went down to the local auto shop but could not find a replacement listed in the cataloges. Has anyone changed their globes over and if so what brand makes the H9 and H11 White light!![]()
World, I actually found both globes on EBay here is AUST, only cost $36.00 delivered for two H9 and two H11 "X Tec" 4000K HID matched, simply replace the globe no additional transformers or relay wiring required. Brilliant white light. Clay
You can put an H11 for your low beam in place of the H9 and it will give you MUCH brighter light. Its a common mod for the projectors.
