+ Reply to Thread
Results 1 to 16 of 16
Thread: Vy Blowing Lots Of White Smoke
    VY EXECUTIVE WAGON
    Oct 2007
    Unhappy Vy Blowing Lots Of White Smoke
    Just purchased a VY wagon 85,000km. When we start it up it blows lots of white smoke. We took it back and they replaced the Value Stem Seals. We have since empted the tank of fuel and put new fuel in it. It is still blowing smoke ONLY when you first start it. Even when it is not cold???
    Please Help
    JD
    JD is offline Donating Member JD Statesman
    VS Berlina
    Aug 2006
    Deep South, SA
    GOTMYN's Avatar
    GOTMYN is offline Stab it and Steer... GOTMYN Berlina
    Whippled 5.7, VE SV6, GU Patrol 3.0DI
    Sep 2006
    Mornington, Vic
    Default Smokin VY???
    are you familiar with the difference between Smoke and Steam?
    If so, smell it.. If its hard to breath in, oily smell, then its Oil from somewhere like Valve stem seals, If its steam, its condensation, or a Leaky head gasket(water into cylinder)"only if you are topping up the water on a regular basis because its low... But if it has a Fuel kind of smell, then possibly a leaking injector, putting fuel into the cylinder between the time you turn the key from ignition to start........
    If I'm not pulling Toyota's out of the Bush, I'm pulling 12's in the Sig :-)
    88GreenVN's Avatar
    88GreenVN is offline Almost not here! 88GreenVN W427 88GreenVN W427 88GreenVN W427 88GreenVN W427
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    What ever it is it cant be good. White smoke would point toward coolant getting into the cylinder some how. Blown head gasket of cracked head/block.
    Can you smell coolant at all? Is thew oil cap milky on the inside?
    and 3 Dangerous non ABS VN's
    AttaBoy is offline WTF?!?! AttaBoy Statesman
    VS Acclaim V6
    May 2005
    Did you even test drive the car before you bought it. Was it blowing smoke before you even sealed the deal??
    You just bought a problematic car.
    If you got it from a dealer - send it back. seriously you should not have to go through this as a new owner thats just ridiculous.
    White smoke usually indicates coolant entering the combustion chamber. you probable have a blown head gasket.
    VY EXECUTIVE WAGON
    Oct 2007
    I am scared now. Head gasket?? It is deffentley not condensation. It does not smell like oil or coolant. It only does it when you first start it up - HOT or COLD and not every time???
    HELP
    1999 Honda Accord Wagon 2.3 VTEC
    Oct 2005
    Wellington, New Zealand (Yes i know yet another KIWI)
    Take it back and ask for your money back ASAP. its not worth the risk. if this is only happening after a few days who knows what else is just around the corner to fail mechanicly.
    VS Acclaim V6
    May 2005
    It doesn't have to smell like coolant, if its steam usually only thing I can think of is coolant.
    Or maybe you have heavy condensation in your exhaust or muffler, Id get it check anyway just to make sure. Normally the condensation will go away after a drive.
    VL 86 RB30 Executive Auto
    Jun 2005
    South OZ Adelaide
    Exclamation
    Quote Originally Posted by emma.henningsen View Post
    HELP
    IS the coolant in the overflow bottle getting lower and lower OR are you needing to fill it up every other day??
    The times it does it is it harder to start or run a bit ruff just after the start??
    I was confused now I'm just not so sure!!
    RIP Peter (perfect) Brock....
    VY EXECUTIVE WAGON
    Oct 2007
    I do not think we can get our money back?? It’s just really disappointing. It’s the first time I have spent more the $500 on a car and now we have a driveway full of smoke??
    The coolant is fine the oil is fine. Back to the dealers, and try for the tried time for them to fix it. May be I should of brought a FORD.
    VS Acclaim V6
    May 2005
    Did you had it checked by a mechanic before you even touch your money??
    Did you even take it for a test drive?? Was it a impulse buy??
    I understand that it can be very tempting to buy it especially if you really like the car.
    When it comes to used car whether it 15 years old or 2 years old you still need to be very careful.
    I'd say go back and talk to the dealer. Don't waste your money fixing it.
    Boonz's Avatar
    Boonz is offline the holden mechanic Boonz Maloo Boonz Maloo
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    its more than likely worn out intake manifold gaskets... pretty common with V6's and is the most common cause for loss of coolant...think of it this way. when the car is hot the coolant is pressurised, when the motor is not operating coolant is forced out of the cooling system, past the worn gaskets and into the cylinders so when the motor is started again when cold it is mixing with the air/fuel mixture and making the white smoke until the coolant is cleared from the cylinders.
    VY EXECUTIVE WAGON
    Oct 2007
    We took it for a test drive and was checked by a mechanic. I am very thankful for all your comments. The car is under warranty, but it is just a hassle having to keep taking it back and the same problem still occurs.
    Cool Ute.
    minux's Avatar
    minux is offline Infidel Bear minux W427 minux W427 minux W427 minux W427 minux W427 minux W427 minux W427 minux W427
    300rwkw FG G6ET/2011 Sti Spec R Hatch
    Mini Putt 2 Champion!
    Feb 2005
    Or maybe you should of had a mechanic check the thing before you bought it?
    To me it sounds like it is still valve problems.
    "Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind."
    - Theodor Seuss Geisel
  15. #15
    VY EXECUTIVE WAGON
    Oct 2007
    It had a machincal check. We are just unlucky that the problem has started after we brought it. I am taking it to the RAA for a full inspection. I will let you all know the result.
  16. #16
    Holden Calais supercharged V6
    Jun 2005
    not no worry it only cost $ 600 to get it fixed. at holden other mech's cheaper.. 1 day job
+ Reply to Thread
  1. mazda 626 - blowing white smoke when cold
    By lowrida56 in forum The Pub
    Last Post: 01-05-2007, 09:54 PM
  2. Blowing Smoke
    By COINERS in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 15-01-2007, 01:35 AM
  3. vs blowing smoke
    By lexcedore in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-08-2006, 10:08 AM
  4. Blowing smoke
    By minimefx in forum VL Holden Commodore (1986 - 1988)
    Last Post: 20-07-2006, 08:00 AM
  5. VR Blowing Smoke
    By tr3nt in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-06-2005, 09:19 AM
