+ Reply to Thread
Results 1 to 20 of 20
Thread: question* How to reach high power n/a?
    VY exec
    Sep 2007
    Default question* How to reach high power n/a?
    Hey guys im wondering how id be able to achieve around 170rwkw n/a in my V6 exec. My brother just achieved 160rwkw with intake,exhaust and 98 octane tune. Im hoping to beat him, and just trying to get some rough figures for some relatively easy mods.
    GOTMYN's Avatar
    GOTMYN is offline Stab it and Steer... GOTMYN Berlina
    Whippled 5.7, VE SV6, GU Patrol 3.0DI
    Sep 2006
    Mornington, Vic
    Quote Originally Posted by dean_jely View Post
    Your Brother has 160rwkw??????
    Has to be V8!!! You will generally get anywhere up to or around 140rwkw with a tune and bolt ons, any more would need forced induction!!
    maybe he has 160 at the Flywheel=160fwkw..................
    If I'm not pulling Toyota's out of the Bush, I'm pulling 12's in the Sig :-)
    VY exec
    Sep 2007
    My brother has 160rwkw with exhaust intake and a flash tune. No forced induction mate, ill post a video up of the run.
    GOTMYN's Avatar
    Sep 2006
    Mornington, Vic
    To be honest, I would love to see it and also love evryone that has been bagging out V6's in the past few months to see it!!
    Is his tune from Powerchip? I have done all I can in the way of bolt on's, and ended up with 134rwkw, 160 would be very very nice to say the least!!
    AirStrike's Avatar
    AirStrike is offline Site Administrator AirStrike W427 AirStrike W427 AirStrike W427 AirStrike W427
    2009 G6ET
    Jul 2003
    There is no way in hell it would be 160rwkw with those mods. Simple.
    Do you have a copy of the dyno printout? I would like to see the AT compared with IT.............
    VY exec
    Sep 2007
    Just realised why yous cant believe it, i thaught i put in that its an Xr6
    AirStrike's Avatar
    2009 G6ET
    Jul 2003
    Well that's a totally different thing isn't it........
    GOTMYN's Avatar
    Sep 2006
    Mornington, Vic
    Default Xr6.....
    Well, Yeh Believable, however they dont deliver the goods that well!!
    For you to beat him on the Road, you would only need 140rwkw or there abouts!!
    A stock XR6T has 175rwkw and they only pull a car length over 200mtres on me with just over 130rwkw.........
    You will never beat him on the rollers with just those mod's!!
    AirStrike's Avatar
    2009 G6ET
    Jul 2003
    Quote Originally Posted by VY CHRISSO View Post
    Ummm they ain't 175rwkw stock mate........they only make 180fwkw stock.
    GOTMYN's Avatar
    Sep 2006
    Mornington, Vic
    Quote Originally Posted by AirStrike View Post
    Check out your sources!!! 240fwkw Stock!!
    I did say XR6T which means TURBO!!
    VY exec
    Sep 2007
    yeh my bros car doesnt seem that powerful with 160rwkw, Im not sure if its worth doing all those mods unless u force induct later on. How much for a decent easy na mod setup you guys recon?
    VY S PAC 5 speed
    Apr 2007
    WA
    hey mate
    Your looking about $1500 - $2500, depends what you get really
    GOTMYN's Avatar
    Sep 2006
    Mornington, Vic
    Roller Rockers $600,
    Extractors $600,(fitted)
    Exhaust $600,(fitted)
    CAI, $free do it urself.
    3.9 Diff Gears $ 1200,(fitted) now you will be cookin!!
    1991_Vn2nV's Avatar
    1991_Vn2nV is offline Donating Member 1991_Vn2nV GTS 1991_Vn2nV GTS
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    $1200 fitted for diff gears! fark me dead... Lucky I have a VN I guess $700 fitted for brand new 3.9's
  15. #15
    GOTMYN's Avatar
    Sep 2006
    Mornington, Vic
    Yeh $1200 for Diff Gears, I should have included the fact that at that price you will get a complete reco diff with LSD and 3.9 Gears, as the Exec do not have LSD... Diff gears only, prob about $500 or so.....
  16. #16
    VY exec
    Sep 2007
    thanks for the help guys, thaught i was out of league with the ecotec as forced induction isnt an option with these new p plate laws.
  17. #17
    GOTMYN's Avatar
    Sep 2006
    Mornington, Vic
    Default Cai...
    Hi Mate, As I said on PM, Here are pic's for you.
    Just a piece of 5" plastic hose, about 200mm, 2 Elbows and four hose clamps for the rubber sleeves and you are away, I used a 5" hole saw for the air box, and then sealed it up with sensor safe silicone, and while doing that I sealed up the factory CAI with it as well, I cut a small section out of the plastic deflector under the car to allow for Air to enter Elbow, and Fixed it Via a self drilling/Tapping screw into the Radiator support Panel. as easy as that, about 2 hours all up. Anywhere above 60kmh and your imagination would be saying that the Air would be getting almost forced into the engine instead of it having to suck for it!!
    Yes you do get a bit of crap inside the air box with this set up, but I make it a Sunday ritual to take out my filter and blow it out with compressed air, The picture shown is the inside of the box after 1 month without cleaning it, so it's not too bad, I do not consider putting a piece of mesh over air pick up, as it will be restrictive and defeat the purpose of the whole mod.... I also sprayed a small amount of Pure and Simple/cooking spray onto the inside top of the Air box, Past the filter, to see if any sand dirt etc was getting past the filter, and to my surprise, the oil stayed clean and nothing was stuck to it.....
    Cheers, Chrisso.
  18. #18
    VY S PAC 5 speed
    Apr 2007
    WA
    Yes you do get a lot of crap inside the air box with this set up, but I make it a Sunday ritual to take out my filter and blow it out with compressed air, I do not consider putting a piece of mesh over air pick up, as it will be restrictive and defeat the purpose of the whole mod.... I also sprayed a small amount of Pure and Simple/cooking spray onto the inside top of the Air box, Past the filter, to see if any sand dirt etc was getting past the filter, and to my surprise, the oil stayed clean and nothing was stuck to it.....
    Cheers, Chrisso.
    Or you could buy a SS induction kit, though it will cost alot more than Chrisso set up, though you want have to worry about dirt etc getting into your air box
  19. #19
    VY exec
    Sep 2007
    GOTMYN's Avatar
    Sep 2006
    Mornington, Vic
    Dean,
    Have you done the CAI yet??
+ Reply to Thread
  1. Bolt on goal is now in reach!!
    By AirStrike in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-03-2007, 05:15 PM
  2. High ratio rockers low end power???
    By spice weasel (BAM) in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-01-2007, 01:30 PM
  3. VP losing power at high speed
    By virgonc in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-12-2006, 08:02 AM
  4. Loss of power at high altitude.
    By snowmobile in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-06-2006, 07:20 PM
  5. reach wiring???
    By Whitevtberlina in forum Car Audio
    Last Post: 25-04-2006, 05:46 PM
