Was thinking of changing spar plugs in my stock v6 ,,, what are the benefits of
this and can anyone recommend a brand or price of any good ones for better
performance?
I go for NGK or bosch.
If your sparkies aren't that old then you will not notice any difference. You might wanna change the leads if you don't know when they were replaced or if it looks worn.
iridium tips,ngk BPR6IX-10 is the code
If they are in good nick, don't change them, no benefits at all.
I use NGK's. Iridiums are a bit of overkill IMO. Take one out and check it, if the gap is more than 1.5mm and the electrode is a bit rounded, then replace them.
Just use standard issue holden plugs. These work just fine even on performance cars.
"Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind."
- Theodor Seuss Geisel
I use Bosch Super 4
I also use bosch for anything else that i need (leads/coils/belts etc etc) excellent stuff![]()
96 EF2 Futura I6 Auto SedanSuperlows Front/Rear with Monroe GT Sport's, EL XR Front, 16" Tickford Wheels with 225/50 Wanlis
, 5% Tint, Sony Headunit/ 6 1/2" 190w Speaker's, Fram Air Filter/XR6T Snorkle, Pacemaker 4499's/Hi Flow Cat/2.5 inch Redback, 4.11's/LSD
15.37 @ 147 KPH
15.37 @ 147 KPH
I tried getting some Super4's but they are practically impossible to get. They are phasing them out apparently. Instread i go the super plus plugs with yttrium. They are standard HR8DCV+ with a 1.3mm gap which attracted me as i run dual fuel. I dont need to regap it. Tell me, is the Heat range 8 which is standard for Bosch, hotter than 6 which is the standard for ngk for these cars ??? IM hoping the Bosch isnt too hot a plug. I just want standard, they dont make the sper plus plug in a cooler 7 for some reason.
where did you buy them? because supercheap stock bosch. as for the heat range i couldnt tell you sorry
15.37 @ 147 KPH
Yeah i looked at a few supercheaps and their system told me they are phasing them out.bursons etc told me the same. This is for the Super 4's, they going to a platinum and iridium plugs
