Results 1 to 9 of 9
Thread: VY Series 1 Berlina fog lamps
    VY Berlina Wagon
    Mar 2007
    Default VY Series 1 Berlina fog lamps
    Hi,
    Ok I have a series 1 berlina, getting hold of the fog lamps, the bessils and the bottom part of the front bar with the lamp holes, Is no problem.
    The head lamp switch has the pull out for fog lamp feature.
    the problem is on the dash there doesnt seem to be an indicator for the fog lamps and in the fuse/relay box in the engine bay, there is a spot for the fog relay but no wiring going to it. has any one had this problem and if so how do i get it all happening.
    Loupy31
    vy series 2 v8 berlina
    Dec 2006
    series 1 & series 2 must use a different instument panel because if you order a panel from holden you have to specify whether it's for a series 1 or 2.Cheers
    VY Berlina Series 2
    May 2007
    SA
    yeah i think they do use a diffrent cluster
    VY SERIES 1-has a grey plug on the dash cluster
    VY Series 2 and all VZ's use a Blue plug on the cluster
    VY Berlina Series 2
    May 2007
    SA
    i should mention, the cluster's not interchangeable
    and also your cluster should work, cause it was an option on Series 1 berlinas, and standard on Calais
    also by memory if you ring up holdens, you might be able to purchase the foglight accessory wiring loom, as what i've been told in SA from VT onwards they had the main loom, then if the foglight were ordered, they plugged in that loom aswell etc
    10 VE SSV,03 VY Exec, 83 Wb Statesman
    Aug 2005
    im confused im about to do this conversion myself ive ordered all the bits but have been told there is no loom available for purchase
    Jun 2004
    brisbane
    the light switch should pull out to turn the fogs on.if it doesnt then you wont have the loom in your car.mine didnt.you may be able to change the switch & get an auto electrician to wire it in,i dont know i didnt go down that track.i just got a little switch fitted on the drop down panel of the dash,down under the light switch.is in easy reach & just lights up when its on.be careful where you put the switch and make sure there is nothing behind it when the panel is closed up.pic attached
    cheers
    warrick
    Attached Thumbnails Attached Thumbnails VY Series 1 Berlina fog lamps-light-switch.jpg
    Aug 2005
    your switch is pretty neat but id rather have it wired to the factory headlight switch.
    i stumbled accross a website last night showing how to hook up an aftermarket set of fog lights to the factory switch.
    so i guess i use the same method with the genuine set seeing is i have no loom in place.
    VY Berlina Series 2
    May 2007
    SA
    the are 2 types of factory swiches, some have the foglight logo bit on the part you hold to turn them on/off/parkers/auto
    other dont have that which means no foglights
    i have a factory workshop manual so i i get time i'll sus it out- for ya
    Aug 2005
    Quote Originally Posted by exec24 View Post
    id say not actually having fog lights in your front bar means no fog lights
  1. vx berlina series 1 and series 2 whats the difference
    By rgormley in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-08-2010, 06:40 PM
  2. Series II VX Berlina
    By B-T-GiZzLe in forum VT - VX - VU - WH - V2
    Last Post: 27-09-2006, 09:47 PM
  3. VXII Berlina Fog Lamps
    By myberlina in forum Electrical Wiring / Questions
    Last Post: 27-12-2005, 03:55 PM
  4. My VN Berlina Series II
    By Commodore_Chick in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-06-2005, 10:56 PM
  5. back roof reading lamps Vp berlina
    By fu2 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-12-2004, 01:54 PM
