Results 1 to 3 of 3
Thread: VY Door out of alignment?
    VYII
    Oct 2007
    Default VY Door out of alignment?
    Hi Guys
    After detailing my new purchase VY series 2 Berlina, have noticed the driver’s door appears to be a little out of alignment as have also notice slight air noise when driving 90klm plus.
    Can identify this as the groove in the top 1/4 of the panel does not line up with the rear door (front door setting to high 2-3mm) and the rubber flexible seal on top of the driver door sits 2mm higher than the passenger door and petreuds pass the body work just as it starts to curve down towards the mirror which I believe is where the wind noise is coming from. Where on the passenger side the groove lines up and the rubber seal is tucked in with no wind noise apparent.
    Further to this when the door is shut it feels like it making contact with the catch before it making a good seal with the rubbers and the panel is not completely flush with the rear door
    It appears the door either needs to make contact with the catch later (move latch further in) which might cause the door to move slightly down as the resistance from the seals could align the door, or I need to drop the catch as well?
    Is there any adjustment within the catch/lock located on the door?
    Any idea what could have caused this? Door slamming
    Car is a 2004 company car from my work place and although I didn't drive it, I know it has not been involved in a single accident.
    Your help appreciated.
    AttaBoy is offline WTF?!?!
    VS Acclaim V6
    May 2005
    How do you know it has not been involved in an accident??
    How is the other doors?? It could be a little chassis twist which I doubt. I'm not sure on yours but on my car I can adjust the catch mechanism slightly.
    VT Berlina 07's Avatar
    VT Berlina 07 is offline 15.37 @ 147 KPH
    96 EF2 Futura I6 Auto
    Apr 2007
    Sydney, NSW
    hi, do you have any pics?
    96 EF2 Futura I6 Auto Sedan Superlows Front/Rear with Monroe GT Sport's, EL XR Front, 16" Tickford Wheels with 225/50 Wanlis, 5% Tint, Sony Headunit/ 6 1/2" 190w Speaker's, Fram Air Filter/XR6T Snorkle, Pacemaker 4499's/Hi Flow Cat/2.5 inch Redback, 4.11's/LSD 15.37 @ 147 KPH
  1. irs diff alignment
    By dagsy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-02-2007, 07:56 AM
  2. Wheel Alignment
    By Shounak in forum General
    Last Post: 29-10-2006, 06:55 PM
  3. Alignment or Balance?
    By majobe in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-03-2006, 10:53 PM
  4. VS Door alignment
    By ruler71 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-01-2006, 10:00 PM
  5. Wheel alignment
    By MasterOfReality in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-05-2004, 02:49 PM
