Results 1 to 10 of 10
Thread: removing headlights
    VY - Series II - S Pac
    Nov 2007
    Default removing headlights
    hey guys just had a lil mishap. was changing the bulbs on my parkers and i managed to drop the bulb inside the headlight.
    i tried taking the lamp out but wasn't successful. I took off the front grill to get to the last bolt. but couldnt wiggle the mofo out
    is there any way to take out the headlights without removing the front bumper??
    Nov 2007
    VY II S Pack A4
    Jan 2007
    I just had the same problem this morning, was installing LED bulbs for the parkers. The left light was fine, bit tight to wriggle the parker thing out, but for the right headlight I needed to remove (just unbolt) the battery to have enough room to wriggle the parker out. After finally getting it it, I turned on the parkers and one wasn't working, turns out the bulb fell into the headlight. I tried to vaccum it out, then also tried to take the headlight out without removing the bumper but that didnt work so I ended up taking off the front bumper (I quickly searched the forum for tips on taking the bumper off and followed "Windsurfing VY Wagon"s post)
    Taking the bumper off was the only way for me to get the headlight out, as it gets jammed between the bumper. There was another tricky bit of actually getting the bulb out of the headlight, as the parker falls into other compartments of the headlight, so it will take a bit of shaking to get it out.
    If you are asking about whether you need to remove the bumper to get the headlight out, I couldn't see another way of doing it.
    Nov 2007
    Quote Originally Posted by Jobby View Post
    ahh ok thanks for that.. but yeah dun need to take it out anymore my friend reckons its fallen out while driving lolz... so he jsut needs to buy another one tho..
    Holden2gether's Avatar
    Holden2gether is offline The short,chunky fella
    VY S
    Oct 2006
    Christchurch,New Zealand
    You can get those little round magnets on a telescoping rod thingies. Go fishing,if the bulbs got any metal at all the magnet should pull it right back out the hole it fell in. Just for future reference.
    VYII
    Oct 2007
    VY II S Pack A4
    Jan 2007
    Quote Originally Posted by hockysa View Post
    If it fell into the headlight, it seems unlikely it would fall out while driving as the only holes for it to fall out from are the plugs/caps. Even with the headlight out, sometimes it seemed like it wasn't even there as we couldn't see it or hear it rattling. If it's still inside, you may even need to take apart the headlight if it's in an awkward spot.
    09 VE SIDI SV6 Sportwagon
    Apr 2006
    Margate, QLD
    Same thing happened to me (twice). The first time i found a broken off antenna from an old radio, and stuck a wad of sticky tape on the end and managed to fit it in there and got the bulb to stick to it. Bloody fluke i say. The second time i dropped the led in the right side behind the air filter box which has less room, so i was less successful and is still in there.
    You guys think of any reason as to why the guy doing my service would have removed the white led's and replaced them with crap yellow bulbs again? havent had a chance to ask him, but though it was annoying and odd.
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    Guys
    Removing the bumper facia is the only way of removing the leadlamp assembly. It takes aoout five minutes to remove the facia - its only held on by three screws at the top, immediately in front of the radiator, two on either side on the lip of the wheel arch (one at top, one below which you have to get down low to see, and two hidden plastic screw clips behind the number plate. Once you have removed them all, get a friend to support one side and simply pull the ends of the facia outwards and forwards to unclip them from the guards. The whole thing weighs about five kilos. Put it to one side carefully to avoid damaging the paint. Replacement takes about the same time, only trick is to clip the two ends back into the bottom of the front guards first before replacing any screws.
    VE Omega Sportwagon
    May 2012
    Thanks for the information supplied herein.
    Discovered there were no bolts behind the number plate and nothing for them to go in.... oh well.
    Makes removal and installation of the VE bumper look very complicate in comparison!!!
    Thanks again.
  1. Removing VT Headlights!
    By Timzo in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-02-2012, 10:12 PM
  2. Exec/Acclaim Headlights --> SS Headlights for $80 ...
    By nEb. in forum VY Holden Commodore (2002 - 2004)
    Last Post: 23-06-2011, 11:06 PM
  3. HID & VN Headlights
    By HoZy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-10-2006, 04:36 PM
  4. where to buy new headlights ?
    By INSAYN in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-09-2005, 05:12 PM
  5. FS - VP headlights x2
    By s0sage in forum Parts And Other Items For Sale
    Last Post: 14-05-2005, 04:10 PM
