Results 1 to 6 of 6
Thread: "Check Oil" Alert Message
    2011 Commodore SV6 SII
    Sep 2006
    Default "Check Oil" Alert Message
    Another one of those "has this happened to you?" threads.
    Hopped into the Commodore one afternoon, straight after turning the key got the "Check Oil" alert flashing up on the display with the accompanying musical tune. Even after I cleared the alert off, the little oil sign stayed on the display.
    First thing that makes me curious is that it had a service not long ago. Next I check the oil - all ok there. I turn the car off, turn it on and no alert this time.
    This has happened a couple of times when I've started. I quickly turn it off, back on again and it's fine. It hasn't happened again now for a couple of weeks.
    Any ideas?
    vt exec
    Sep 2007
    take the car to a dealership and it might need a sps which is basically a bcm software update
    if u cant find it grind it
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Could also be a dicky oil pressure sender.
    Visit my Facebook page
    vy ss commodore 5.7ltr
    Jul 2006
    yeh was going to suggest the oil pressure switch, all so do they have a switch that if a certain grade of oil recomended by holden isn't used it can set the pressure switch or oil level switch off, might be completly wrong there, but i know of some jap cars and european cars having this, it lets you know if the oil is low, but if the wrong vescosity oil is used it will set it off, might be a 10/30 like recomended but the grade off oil might be wrong, i know we have this with the new civic typeR at honda (awesome car buy the way, little pocket rocket, like a smaller hatch version of the s2000 ) and i think mercs and bmw's might have this too now, just a thought, but like i said could be completely wrong
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    The switch is basically an on/off switch, when the pressure isn't sufficient to keep it off, it turns on. A faulty switch wouldn't operate correctly. GMH wouldn't spend that kind of money needed to install sensors to measure the viscosity of the oil on a Commodore.
    vt exec
    Sep 2007
    i had this happen to dads car the other day and all it was just a code loged in the ecu so they deleated it nd it fixed it
  1. VT series 1 door "check strap"
    By cliffo78 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-10-2007, 11:37 AM
  2. "Shift Up" Error message *HELP*
    By dean_jely in forum VY Holden Commodore (2002 - 2004)
    Last Post: 30-09-2007, 05:17 PM
  3. Should I wait for "systemcheck ok" message to start the car?
    By vinni30 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 27-01-2007, 02:35 PM
  4. Is the warning "service engine oil" the same as "check oil" ?
    By morris in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 04-12-2006, 04:36 PM
  5. "SRS Airbag Fault" message
    By davey g-force in forum VY Holden Commodore (2002 - 2004)
    Last Post: 19-06-2006, 07:41 AM
