Results 1 to 5 of 5
Thread: Cams
    Aug 2006
    Default Cams
    How hard is it to change the cam in the 3.8L V6??
    nicko's Avatar
    nicko is offline Carbon Positive - DO IT!!
    75 cruiser ute
    Sep 2007
    sa
    Depends if u know what your doing or not. be a days work in it easily. provided you documented the process of talking it apart you should have no problems doing it.
    no longer a hoon by association - the commodore is gone
    GMM CAMMED and STALLED VT SS 5.7
    Sep 2007
    Melton,Victoria
    take the engine out, strip it, install cam, build it again and then put the engine back in. can take a while if u do it urself. took my mechanic a few days but im geuessomg thats with alot of distractions amnd stuff like that
    vy ss commodore 5.7ltr
    Jul 2006
    yeh if you know what your doing and av done it a few times before, you could do it in a weekend taking your time or in a day or so, going for it providing you have engine crane etc, or you might be able to jack the motor up a bit by undoing the engine mounts and carefully useing a jack with a block of wood underneath the sump area, then strip the top half of the motor and remove the cam, you'll have to remove the radiator and front grill, but if you don't have an engine crane, might be an easier way and you don't have to remove the motor completly, then just jack it up enough to get the cam out.
    Aug 2006
    any suggestions wheres the best place to source a cam?
  1. VS V8 cams
    By craney in forum General Discussion
    Last Post: 18-03-2007, 04:43 PM
  2. Cams
    By DVS87 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 21-04-2006, 07:11 PM
  3. cams
    By old55 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 14-02-2006, 08:37 AM
  4. Cams cams cams!!
    By VN_Luke in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-02-2006, 09:49 AM
  5. cams
    By mattya in forum V6 Development And Modification
    Last Post: 14-09-2005, 09:18 PM
