Originally Posted by
freeLancer
Hi there.
I actually removed mine this morning. I have removed the plastic but the bonding strip / paste is still there. It's a bit of a struggle to get the bonding paste out. I was told to cut it out with knife.
The plastic strip wasn't too difficult for me as mine had already come loose a bit on the one end. So I just gently (sometime a little less gently) pull it from the one end to the other. It took about 10 minutes to pull it.
I had a stanley knife and a very flat, small steel ruler on hand to weaken where the bonding is a bit stronger, but didn't have to use them much.
What's left are 2 strips, 1 of some kind of tape on the top and 1 of some bonding paste at the bottom. The paste is difficult to get out. The ruler helps with the tape.
Does anyone know what the paste and tape are and where can I buy them. After removing it, I am going to stick it back on.
Do you know where I can buy the plastic strip as well. It's for the drivers door and how much is it roughly.
Thanks.
