Results 1 to 6 of 6
Thread: Installing gauges?
    Silver surfer is offline Banned
    04 VY Executive
    May 2007
    Default Installing gauges?
    well I got my gauges today (water, oil and volts) now the install instructions say that the sender for the oil and water is usually installed in the same hole from which the warning light sender is removed.
    now no where in the instructions does it say remove the warning light sender and if it did would that not leave the light on the dash illuminated perminently????
    any help would be great.
    Dave
    __________________
    04' VY s11 Cosmo "S"
    Jul 2005
    South Eastern Suburbs Melbourne
    oil pressure sender - buy a tee piece, 1/4' npt. remove factory switch, fit tee piece, refit factory switch (depending on the size of the tee piece you may have to extend your wiring to be able to plug it back in) heres a thread with a pic for you.
    oil pressure gauge install question
    volts guage i earthed to the alternator earth, and earthed oil pressure to an existing earth in the passenger footwell. as for wiring up the gauges, i got power from pink wire from ignition, and got illumination from a brown and white wire from behind the instrument cluster.
    hope this helps
    04 VY Executive
    May 2007
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    just buy another t-peice. not sure on ecotec but there should be 2 sensors behind/under the altenator area. one should be the coolant temp sensor and the other the gauge sender. you could tee of either or replace the gauge sender with your own (rendering the one in cluster useless)
    Power is measured in DECIBEL
    04 VY Executive
    May 2007
    ok i got the water temp figured there is a thing that drift performance products have called a temperature sender adaptor pretty much what is, is a adaptor that you put in the radiator hose its self, cutting out part of the hose the sensor then screws into this.
    the guy at auto barn told me i need a sandwich plate to do the oil sender and said a t peice would not fit in the vy to do it.
    Jul 2005
    tee piece works in vy for oil sender, but if you're gonna get oil temp too, well then sandwich plate is the best option. 1/4" threaded tee piece is what you need, and with drift senders, i think they supply 3/8" sender. i bought autometer pro-comp ultra lite gauges and they supply a 1/4" nipple. you'll need 2 nipples, 3/8" female to 1/4" male for the sender (double check your sender thread, or just take with you if you decide to go the tee piece way), and also another nipple 1/4" male to 1/4" male to screw into the tee piece to go into the hole where the pressure switch would be. i got mine from pirtek. cost me $14 i think, 1 tee piece, 1 m-m nipple. just ask for the smallest tee piece. i know that's what i asked for lol
    i hope this helped
  1. Installing gauges?
    By Silver surfer in forum Electrical Wiring / Questions
    Last Post: 28-11-2007, 05:46 PM
  2. Installing Gauges...water + Oil Temp, Oil Pressure Help Needed
    By VXGASSED in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-04-2006, 04:29 PM
  3. Gauges
    By raZel in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-03-2006, 08:43 PM
  4. vs gauges
    By skb in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-12-2005, 03:53 PM
  5. installing extra gauges
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 30-08-2005, 10:29 AM
