Results 1 to 11 of 11
Thread: VY S pac Tyre noise
    VY S II
    Dec 2007
    Default VY S pac Tyre noise
    Hello everyone
    Im thinking about getting a 2003 VY series 2 s pac only problem is the car makes a wierd noise when slowing down, the guy rekons its because of the wheels/tyres (there 18inch or 17inch (not too sure) it only does it at first quiet a werid noise
    just wondering if anyone could shed some light on this one
    sounds like the wheel bearing to me but is that actually possible for the tyres to have that effect,
    thanks for any help
    maginoodle's Avatar
    maginoodle is offline Donating Member
    vy series2 ss crewman
    Apr 2006
    Now it could be tyres but depending on kays done it could be the diff. Mine has a wierd noise in it after doing 50+ kays and is going in under warrenty to be fixed.
    Cheers Shane
    heres my ride, i know its not much but its mine
    http://forums.justcommodores.com.au/...-ss-crewy.html
    and heres my new project
    http://forums.justcommodores.com.au/...ml#post1104629
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    Default Definitely could be tyre noise
    Hi Red,
    The noise you describe definitely could be tyre noise, caused by either the design of the tyre tread pattern, tyre compound or improper wear.
    The simplest one to check is the tyre wear pattern. Some tyres develop a real howl at low speed because of this. I had an XC Barina with 17's and a set of cheap and nasty Asian brand tyres purchased through Tyrepower. The ride was hard as a truck, no give in the low profiles tyre and they howled their heads off in parking areas where you would only be doing about 10 - 15 k's. Uneven war due to a sagged front end didn't help. Selling the Barina did.
    As you indicated that the noise in the VY occurs when slowing down, I suspect the prblem is excessive tyre wea, caused by poor wheel alignment.
    Other tyres are noisy on some surfaces and not others. My Mark V Golf had Michelins from the factory and they were extremely noisy on coarse bitumen.
    Regards
    pj
    VT Berlina 07's Avatar
    VT Berlina 07 is offline 15.37 @ 147 KPH
    96 EF2 Futura I6 Auto
    Apr 2007
    Sydney, NSW
    hi, do you mean when having medium-hard pressure on the brake pedal?
    96 EF2 Futura I6 Auto Sedan Superlows Front/Rear with Monroe GT Sport's, EL XR Front, 16" Tickford Wheels with 225/50 Wanlis, 5% Tint, Sony Headunit/ 6 1/2" 190w Speaker's, Fram Air Filter/XR6T Snorkle, Pacemaker 4499's/Hi Flow Cat/2.5 inch Redback, 4.11's/LSD 15.37 @ 147 KPH
    VY S II
    Dec 2007
    Flat_White is offline Banned
    Rolls Royce "Fantom"
    Apr 2008
    sorry to revive an old thread but i am having the same problem... with exact same car too.
    it seems that when i acclerate to about 15-25kms the noise occurs... it sounds a bit like tyre noise, but mainly like a real friction noise.
    it seems to be coming from the front left of the car....
    really starting to stress at this stage
    Apr 2008
    and when i decelerate to the same speed range it also occurs...
    noise still occurs whether braking or not!
    VY SS 5.7 A4
    Apr 2009
    Quote Originally Posted by Flat_White View Post
    Bugger no replies to this guy either for a year. I have exactly the same prob as this guy. Sound comes from front left more than anywhere. bearings seems fine im lost.
    Calaber's Avatar
    CG Captiva SX
    Nov 2007
    Run your hand across the tread on the front tyres. See if you can feel a raised edge on the tread pattern. It will feel quite obvious - if you can feel it, have a good look at the tyres and you should be able to see a fine raised lip on the tread at the front of each tread block. Generally, you will find it occurring on the outer side of the tyre. If you have this pattern of wear, it is likely to be caused by excessive toe-in.
    Irregular wear on tyres, caused by improper wheel alighnment, can create a noise that is most obvious at low speeds, particularly when you are slowing down on smooth bitumen. I have experienced it on a few cars and the best description is a loud humming sound that diminishes as you slow down.
    VY SS 5.7 A4
    Apr 2009
    Talking
    Quote Originally Posted by Calaber View Post
    BINGO!! ha ha. it was tires and wheel alignment/ballance more the later. Thanx for the suggestion.The dealers mechanic was sure it was the transmission as the noise was more of a whiny grind than tire sound and had a fair vibration that felt mechanical and front left or at least mid body. He sent it off to a tranny place (and I dont mean a shemale brothel lol) but they sent it back with no probs but recommended all 4 wheels be rebalanced and aligned. I did find that the tires had a lip like you described but on the outer moreso than inner. Best part is that not only did I get the probs sorted, I got new(not machined but new) brakes (discs and pads) and new tires under 2nd hand warranty. ha ha ha my warranty doesnt even cover brakes and tires at all ha ha ha. They were all replaced by the dealers mechanic as he narrowed down the possible causes. I shouldnt laugh. They were looking after a customer and thats rare in after sales service in 2nd hand cars. I will recommend them. they have a few more SS's on the lot now and another black one and a silver R8 that looks good for 34k starting price. Could beat them down for sure. I did on mine.
    Calaber's Avatar
    CG Captiva SX
    Nov 2007
    Weel done. Glad to hear that it's fixed. The dealer sure looked after you well.
  1. tyre noise
    By BUSTER1 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 25-04-2007, 05:11 PM
  2. Tyre Noise --- Plz help
    By sno in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-12-2006, 09:10 PM
  3. Noise From the Brake/Tyre
    By Jules86 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 14-07-2006, 09:48 PM
  4. Wheel bearing or tyre noise?
    By Nuffy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-11-2005, 03:14 PM
  5. Replies: 3
    Last Post: 09-09-2005, 11:11 PM
