Results 1 to 13 of 13
Thread: Vy Sports Binnacle
    talgenn Guest
    Has anybody installed the sports binnacle with the extra two guages after buying the car?
    I own a VY Clubby and i am interested in fitting the extra two guages.
    Do you know if all wireing looms in the dash have the required connections?
    Is it easy to install?
    fourstar82's Avatar
    fourstar82 is offline Graphic Designer
    VYII 25th Anniversary
    Jan 2004
    Templestowe, Melbourne
    Try JHP They're in Melbourne but they do freight interstate i think.
    Andy
    Back in the hope things have settled down...
    vyss350 Guest
    QUOTE (talgenn @ Jan 6 2004, 12:56 PM) Has anybody installed the sports binnacle with the extra two guages after buying the car?
    talgenn,
    how did u go with the info on the binnacle guages?
    did u have any hastles? im thinkn of doin the same thing.
    whats it cost, etc?
    talgenn Guest
    I ended up going to my local holden dealer and found that they sell a kit with all the necessary parts to do the job. They supply wiring loom, guages and a handy set of instructions to guide your way through the installation process. There is a small wiring patch you need to install to be able to hook uo the new loom. You will also need to bolt on a VDO pressure sender on th engine. (just above the oil filter). The whole thing cost me about $650, a little pricey but well worth it, it totally changes the look of your dash.
    Good Luck........
    vyss350 Guest
    QUOTE (talgenn @ Feb 12 2004, 05:23 PM) I ended up going to my local holden dealer and found that they sell a kit with all the necessary parts to do the job. They supply wiring loom, guages and a handy set of instructions to guide your way through the installation process. There is a small wiring patch you need to install to be able to hook uo the new loom. You will also need to bolt on a VDO pressure sender on th engine. (just above the oil filter). The whole thing cost me about $650, a little pricey but well worth it, it totally changes the look of your dash.
    Good Luck........
    Thanks for the info, i will chase it up too.
    did you do all the instalations your self?
    talgenn Guest
    HSV COUPE 4
    Sep 2005
    Quote Originally Posted by talgenn
    If you try JHP www.############ they have the genuine HSV kit to suit all VYs, even with coloured dials
    VY Family Truckster
    Aug 2005
    I installed some in my VY, used two autometer gauges, oil pressure, and trans temp cost half the price of the HSV one and IMO looks better
    VS V6 T5 & VY V6 M35 UTE
    Oct 2004
    Jurien Bay WA
    I ended up going to my local holden dealer. There is a small wiring patch you need to install to be able to hook uo the new loom.
    the small wiring patch that you mention does it come with the kit and is it just a plug in set up thats easy to work out ?
    Aussie Aussie Aussie, Oi Oi Oi .
    Torquative's Avatar
    Torquative is offline go in Luxury
    Grandpa Spec WK Statey
    Jun 2005
    is it possible to find out how to remove the plastic bit off the dash without damaging either it or the dash?
    A little OT but I'm thinking of installing an SS "bin" in that area for remotes / cards etc but Ive been told theres bits and pieces under the plastic to watch out for, and that the bin wont suit, so I want to have a look before I waste money on the bin itself but dont want to damage either dash or plastic in case it cant be done!
    VY Family Truckster
    Aug 2005
    I prized mine off with a small flat blade screw driver and it didnt make a mark.
    Torquative's Avatar
    Jun 2005
    got it thanks!
    Had a look, I dont reckon it'll fit but ive got a SS bin coming in from Melbourne, hopefully before the weekend, so we'll see
    camvyss's Avatar
    camvyss is offline Doof, Doof, Doof
    VY2 SS 5.7L A4
    Sep 2005
    Really Rural Queensland
    I just got a quote back from JHP at $900. That's well over the genuine Holden at $650. So personally I'm going with the genuine.
  1. HSV Binnacle
    By Mr_Calais in forum VY Holden Commodore (2002 - 2004)
    Last Post: 02-10-2007, 05:53 PM
  2. VZ into VY binnacle guages
    By calaiscruiser76 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 08-07-2006, 07:43 PM
  3. My binnacle installation, Thanks all!
    By Lumps of cheese in forum VY Holden Commodore (2002 - 2004)
    Last Post: 28-06-2006, 06:20 PM
  4. vy binnacle instruments
    By dermie in forum VY Holden Commodore (2002 - 2004)
    Last Post: 17-09-2005, 02:40 PM
