Results 1 to 5 of 5
Thread: VY Key
    was vn s pack now VY S2
    Jan 2005
    Default VY Key
    Hi
    My other key for my VY has got broken "buttons" That is the rubber over them
    My Q is can this be replaced or is a new key the only answer
    BTW this is not a spare key
    Ta in Advance
    DUK13Y's Avatar
    DUK13Y is offline Now w/Phreddied Dash
    VYII Berlina, '97 Lancer
    Breakout Champion! Tricky Duck Volleyball Champion!
    Nov 2007
    Sydney, Australia
    if its only the rubber thats broken then my only idea is to get your spare key, pull both keys apart (2 screws on the back) and just swap the face plate.
    that way your spare key will have the damaged rubber buttons and your normal key will look fine.
    hope this helps a bit. sorry i couldn't be more helpful.
    A Commodore is a passion. Anything else is just a car
    Silver surfer is offline Banned
    04 VY Executive
    May 2007
    the 2 screws on the back of the ket only allow you to pull out the metal section that unlocks the door manually, to replace the rubber buttons you will be up for a new key,
    vy_storm's Avatar
    vy_storm is offline just another moderator...
    VE Calais V 6L
    May 2005
    the burbs of Adelaide
    They are a sealed unit and not meant to be opened, you can attempt it, but they pretty much never seal the same way again. But yes they are a 1 piece item and not intended to have parts replaced.
    VZ SS 6 SPEED MANUAL
    Apr 2007
    WA
    if i was you mate i would just get a new key made up and be done with it though its up to u...
