Does anyone know how to remove the cover from the drivers side pillar? I am looking to hardwire my GPS unit and want to run the wiring behind the pillar and under the dash. Any help would be greatly appreciated.
"I wasn't speeding Officer, I was qualifying"
Hmmm tried that it seems to be joined to the hand rail thingy at the top of the door. So there is no screws or anything holding it on near the vents??
no pull top out and then lift it up and it will slide out of bottom near vents
dont be shy
No its different the cover goes all the way back to the centre pillar where the seat belt is.
oh you want to remove it fully?
where r u planning on putting your gps antena
you shoudlnt need to pull it fully off just unclip it tuck wires and push it back on
to remove fully youll need to take handles off and small plug in middle there is a screw hidden in there
No need for an antenna its just a suction mounted one i have but i dont want to drag the cord all the way to the centre console. The way ive gone is used the smokers kit plug and wired under the dash to this.
Funny, we put our GPS antennas on the dash front or back- through the windscreens better signal.
Subsiste Sermonem Statim
