just wondering what you think bout fixing this up or not?
or how much work n money would have to be put back in to it?
munchy, anythings fixable(usually) but it depends what youd be paying for it.
im only paying 1000 bucks for it nothings touch the motor n the body looks pretty straight n only has 110000 on it so yeh really wanna try to fix it any 1 know how to replace the front part of the engine bay would be really helpful
stick a vz ss front on it, 1000 bucks is an unreal price, engine/trans/diff is worth 2k in itself,
buy it if its too hard to fix wreck in, id imagine you would make at least 3 to 5000 off it in parts,
the radiator support is a bolt on part, the only thing that would concern me is that you maybe need to see a panel beater to fix up the unboltable bit around the battery, fuse box area,
best bet is to strip it from from doors forward anything that dosnt bolt up get it straightened by a panel shop,
oh and does all the doors open and shut as it should
EASTERN CREEK JCNSW 2009
Originally Posted by Commydoor
i would definately fix it. i would try and find a wrecker with the same colour panels. the radiater support isnt hard to do just fiddly. you may find some damage to the chassis rail at the front. but if the k frame hasnt been touched or moved you should be able to straighten it.
heres my ride, i know its not much but its mine
http://forums.justcommodores.com.au/...-ss-crewy.html
and heres my new project
http://forums.justcommodores.com.au/...ml#post1104629
In that engine bay pic it looks to me like there could be chassis damage, which would be a PITA to fix. You'd have to rip everything off the front end to see exactly what damage has been done.
I'd buy it, and see if its fixable, and if not, strip it and sell the parts, you'll easily profit from it![]()
Originally Posted by som
hi, looks like you have picked yourself a bargainas stated already make sure all the doors/boot open and check the gaps between doors and panels to make sure they are all even, that way you can see if the body has moved. also check the front suspension and chassis rails. also did the airbags go off??? if it all works out too much to repair you will easily tripple your money buy selling parts off it. good luck
96 EF2 Futura I6 Auto SedanSuperlows Front/Rear with Monroe GT Sport's, EL XR Front, 16" Tickford Wheels with 225/50 Wanlis
, 5% Tint, Sony Headunit/ 6 1/2" 190w Speaker's, Fram Air Filter/XR6T Snorkle, Pacemaker 4499's/Hi Flow Cat/2.5 inch Redback, 4.11's/LSD
15.37 @ 147 KPH
CHECK OUT MY RIDE
IF I WAS HELPFUL TOO YOU CLICK MY SCALES
"Girls are like domain names, all the good ones are taken."
surprised nobodies said it already...............................It'll buff out.
For $1000 I'd give a go, get a front quarter cut(I think that's the official panelbeater's term for it) and just get the new nose glued on it by a reputable crowd. May need to get an engineers report done once it's complete, not sure of your rules over there. You'd still have a nice car at the end of it for less $ I would imagine.
My old VR was almost damaged as badly, panelbeater pulled it on the chassis jig, new panels and radiator support and you would never have known it had ever been munted.
you should be right with some zip ties and race tape
