Results 1 to 23 of 23
Thread: Faulty door lock actuator
    SinisterVY's Avatar
    SinisterVY is offline "The World Is Yours..."
    2004 VY II S
    Mar 2007
    Sydney, NSW
    Default Faulty door lock actuator
    Hey all....Ive run into the problem of my door lock being stuffed on the rear passenger side. I understand that this is a common fault for the VY and many may have had it fixed under warranty but I dont have the luxury.
    When trying to open the car that door lock never comes up and never locks down either. Anyone know what it takes to replace it and how? How much would I be looking at for the new part?
    All help much appreciated..
    Lumps of cheese's Avatar
    Lumps of cheese is offline Who wants chowder?
    MY08.5 VE V8 CALAIS/2010 Hilux SR D4 Dual cab 4x4
    Boulder Crusher Champion! Balloon Park Champion! Action Fish Champion! 501 Darts Champion! Frogger Champion! Jungle Kid Champion!
    Nov 2005
    Warrnambool
    Silver surfer is offline Banned
    04 VY Executive
    May 2007
    mate had this issue today rang 2 places was quoted 140 at one place and 180 at another and that was just parts not labour, I rang a wreckers and got one for 65 and had it in in 15 minutes not hard to do at all.
    I did the drivers door, there is three torx screws that need to be undone and then the plasic clips popped off the actual rods that the acctuator attatches to then it pulls out put the new one in placing the rods in their respective places and do the clips back up,m thenm screw back in,
    hope this helps if you need any more info just ask.
    2003 VY S1 Commodore Berlina sedan
    Oct 2005
    Wellington, New Zealand (Yes i know yet another KIWI)
    mine has failed once again on my drivers side pasenger door, i got it fixed 6 months ago under new car warranty and it has failed again go it is going in again to get fixed under the warranty the stealership gave on the work they did.
    SinisterVY's Avatar
    2004 VY II S
    Mar 2007
    Sydney, NSW
    Damn! Sound like this is a bit of a chronic problem for the VY. No way im gonna spend 200 bucks on just the part. I might see if i can pick it from the wreckers too.
    I should be able to do the install myself so ill give it a go.
    Anyone else had this issue?
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    holden has changed the part now to stop the problem, so if you go to a wrecker, chances are your gonna get one of the original actuators that will fail in a few months of use...
    Oct 2005
    Quote Originally Posted by Peanuts Inc. View Post
    i must have got one of the old parts then cause mine was only fixed arround 6 months ago by holden while my car was still under new car warranty.
    Holden Calais supercharged V6
    Jun 2005
    same problem with mine at the moment, holden quoted at $ 300 each, + labor , do it your self with set back around $ 150
    04 VY Executive
    May 2007
    holden where champ browns plains zupps told me 140 for the part plus labour and motorama at springwood told me 180 for the part plus labour I went and picked one up from aussie car recyclers for 65 they are in the moss street area of slacks creek check out their site only take about 15 mins to change them over.Aussie Car Recyclers.com.au Auto Spare Parts and Accessories for Cars and 4WD's
    SinisterVY's Avatar
    2004 VY II S
    Mar 2007
    Sydney, NSW
    Damn a full set went on ebay for about 70 bucks!
    Silversurfer: Was your part that you purchased the "fixed" version of the actuator or the one prone to the same problems.
    Would be interesting to know what the difference is and exactly what the miracle fix is
    04 VY Executive
    May 2007
    i noticed that the end of the part number was different and the was a plastic bit that was orange on mine but green on the one i bought so i dont know. Sorry i can't help you out mate
    Doctor Bob's Avatar
    Doctor Bob is offline Grandpa
    VT V6 Exec & VN V6 Exec
    May 2004
    Mornington Peninsula
    the orange/green clips are the later ones, they were done to make it easier to find them in the door when replacing the locks.
    the early ones have blue /brown clips
    Rob
    VY S
    Feb 2008
    I have a slightly different problem. I have 2 stage unlocking. You know pust button once and the driver side front unlocks and push the button the second time and the rest should unlock, but often the other 3 don't. This happens quite often but more so if the car has been deadlocked. I don't think 3 actuators went at the same time. It could be the key ( I have tried both) or some sort of car computer issue.
    anyone with any ideas.
    nicko451's Avatar
    nicko451 is offline Nicko
    VY Executive V6 5Spd
    Sep 2005
  15. #15
    Oct 2005
    Quote Originally Posted by nicko451 View Post
    yeah there was a recall!
    Was there? i didnt know that
  16. #16
    SinisterVY's Avatar
    2004 VY II S
    Mar 2007
    Sydney, NSW
    Quote Originally Posted by Doctor Bob View Post
    Rob
    Dr Bob can you explain what you mean by the clips? My stuffed actuator is still in the car so i havent seen what your reffering to.
    Does anyone have the part numbers? i.e. the older part -vs- the newer one. This would make it easier to differentiate when buying
  17. #17
    Oct 2005
    ive just got mine fixed under warranty, here in NZ aparently it is a $400 part just for the actuator
  18. #18
    04 VY Executive
    May 2007
    the clips are what attaches to the rods on the lock its self from the actuator
    the acutator price here is only 150
  19. #19
    SinisterVY's Avatar
    2004 VY II S
    Mar 2007
    Sydney, NSW
    Ive found a source on ebay with reasonable pricing I just really need the part number so Im sure im buying the newer version of the actuator and not the old one prone to the same problems
  20. #20
    2004 Calais VYII Gen3 5.7L V8 + Impco Sequent LPG
    Mar 2005
    Western Sydney NSW
    I've had a "dodgey" drivers door lock since new.
    Occassionally when I lock the doors (using the remote) the alarm sounds off (to tell me a door failed to lock.. I have a Calais with factory standard alarm). It's always the drivers door that fails. I hit the remote again, and it locks.
    I had it seen to twice under warranty, to fix an actuator, then the controller module (?). Warranty expired before it happened again. It still only happens occassionally.
    Is this the same problem? Has everyone's problem been the actuator failing occassionally or completey dying?
  21. #21
    SinisterVY's Avatar
    2004 VY II S
    Mar 2007
    Sydney, NSW
    calaiscruise: Its sound as though its the exact same problem. Maybe wrose for you because its the drivers door. What a pain in the ass.
    Is anyone able to tell me what the part numbers are for the newer and old version of this part? Apparently the new version is not prone to these issues
  22. #22
    Oct 2005
    Quote Originally Posted by calaiscruise View Post
    If you have had this fixed under warranty before and it was less than a year ago take your car back to holden to get it fixed becuase that repair work they did has got a years cover on it so they should fix it again at their cost.
  23. #23
    VY Acclaim Sedan
    Oct 2005
    Default Try lubricating it
    I had this problem with my front passenger door. My mechanic got me to use a small amount of lanolin type spray on just the knob and moulding behind it. Seems to have fixed the problem for the moment.
  1. ignition/steering lock problems passenger door lock
    By timbuk3 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 06-02-2010, 08:21 PM
  2. Door actuator - help!!
    By dbates in forum VY Holden Commodore (2002 - 2004)
    Last Post: 02-12-2006, 01:29 PM
  3. replace door actuator
    By Graham Adams in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-06-2006, 03:58 PM
  4. Door actuator......Need Help URGENTLY!!!!!
    By fruity in forum VY Holden Commodore (2002 - 2004)
    Last Post: 24-06-2006, 09:04 PM
  5. Door Lock Actuator
    By micko in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 20-04-2004, 06:37 PM
