Results 1 to 14 of 14
Thread: Lowering and towing
    DUK13Y's Avatar
    DUK13Y is offline Now w/Phreddied Dash
    VYII Berlina, '97 Lancer
    Breakout Champion! Tricky Duck Volleyball Champion!
    Nov 2007
    Sydney, Australia
    Default Lowering and towing
    I have a 16ft boat and I wanted to know if I would still be able to lower my car. I think it has FE2 springs because it seems to be lower than most of the other commodores that I sit next to at the lights but I wanted to put SL kings on it.
    The boat weighs about 800kgs. Any help or advice is appreciated.
    A Commodore is a passion. Anything else is just a car
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    you can still tow but its likely to cause your car to hit bumb stops and what not.
    I have supers in the VN(had sorry) and then towed a VP on a tandum.. it pushed back end down ALOT and two people in the rears just caused major scrubbing...
    It wouldnt be reccomened to do it. Will likely just cause more damage to wheels or tires or suspension..
    aZk.
    Wanted to buy:
    1. T5 V8 Bellhousing and Clutch fork assembly suit VP
    2. V8 Tail Shaft, T5, Suit IRS VP
    3. T5 VB Gear Box
    PM Me if you got what i need...
    Quote Originally Posted by ryno_vrx View Post
    honestly i doubt it will happen cause kanye west will just interrupt Armageddon anyways
    DUK13Y's Avatar
    Nov 2007
    Sydney, Australia
    ok thanks mate.
    I'll just spend those pennies elsewhere then. One less thing to fork out money for i guess.
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    I have towed several hundred thousand km with VX, VY and now a VE. All had FE2 and never found it to be a problem.
    Reaper
    DUK13Y's Avatar
    Nov 2007
    Sydney, Australia
    Yeah it tows fine at the moment but wanted to know if lower springs would be ok. I'll just put it down my wish list a bit.
    The Windsurfing VY Wagon's Avatar
    The Windsurfing VY Wagon is offline Donating Member
    VY S2 04 S/W
    Oct 2006
    Cairns, QLD
    Hey there mate,
    I have my wagon lowered on King Super Lows with Pedders Comfort Shocks and Pedders Air bags in the rear and she tows my big tadum trailer with all my crap in it.
    She towed fine when I did not have the new shocks as well.
    The air bags are the trick.
    You leave 5PSI in them always then when your going to tow pump them up to 20 to 25PSI.
    It does not rise the rear just prevents the sag from a heavy load.
    The Pedders air bag kit cost I think $220 but there are two types, one for standard height and one for lowered VY Commoders.
    Hope this helps.
    Windsurfing.....
    This is what you call a real sports wagon, BOUY!!!
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    you can also use the genuine superlift rear shocks, the bag actually is attached to the shocks with these and lifts it this way, you can buy the holden kits off ebay for approx 100 bucks,
    the wagon ones would work good with sl's in a sedan
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    VY S2 04 S/W
    Oct 2006
    Cairns, QLD
    I don't know about using the super lifts with lowered springs?
    Might work but I myself will feel better knowing a spring was not going to shake loose if you left the shocks pumped up with no load on them.
    All you can do is try really....
    Windsurfing.....
    DUK13Y's Avatar
    Nov 2007
    Sydney, Australia
    thanks for all the comments. I might give the airbags a go eventually.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    The thing with IRS, is that when you go SL, they are HD and progressive. Your boat is only 800kgs. Lowering the car on SL's won't affect how it tows. The only thing it will do is drop the front of your boat trailer by however much it lowers the car. The others that have posted are towing things a lot heavier than an 800kg boat.
    The air adjustable shocks are a no no. IMO. The springs are designed to carry the load, not the shock, when you put air shocks in the weight is actually carried by the shock, and there is extra strain put on the mounts. I have seen air shocks punch a hole through the boot on a Commodore. Remember that how ever much pressure you put in them, every time you hit a bump, that pressure increases. Add the weight of a trailer and 50psi can turn into 100psi very easily. Go Polyair bags if you were going to use anything.
    Visit my Facebook page
    DUK13Y's Avatar
    Nov 2007
    Sydney, Australia
    ok... so assuming i put sl's all corners, this would tow fine without any probs. Would i need any additional things like camber adjustments, etc? If so what price am i looking at?
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    A camber kit is advisable for the rears. You would probably be looking at around $750-$800 for all the parts. Fitting would be $300-$400 I would say.
    VT Berlina 07's Avatar
    VT Berlina 07 is offline 15.37 @ 147 KPH
    96 EF2 Futura I6 Auto
    Apr 2007
    Sydney, NSW
    before you get to exited about airbags and camber kits, what is the weight on the coupling (normally 10% of the weight of the trailer is a good place to start) so your 800kg boat/trailer combo might only have 80kgs of downforce @ the ball, so stand on your towbar and see how much the car come down
    96 EF2 Futura I6 Auto Sedan Superlows Front/Rear with Monroe GT Sport's, EL XR Front, 16" Tickford Wheels with 225/50 Wanlis, 5% Tint, Sony Headunit/ 6 1/2" 190w Speaker's, Fram Air Filter/XR6T Snorkle, Pacemaker 4499's/Hi Flow Cat/2.5 inch Redback, 4.11's/LSD 15.37 @ 147 KPH
    VY S2 04 S/W
    Oct 2006
    Cairns, QLD
    Just remember tho the airbags are not just for towing but if you ae carrying a heavy load in general like bags of cement or three big mates in the back seat thay will keep the back even.
    Windsurfing.....
  1. Replies: 5
    Last Post: 04-09-2007, 11:15 AM
  2. SV6 and Towing a Car
    By 05 VZ SS in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 21-01-2007, 11:19 PM
  3. towing
    By slappa. in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-11-2006, 07:33 PM
  4. towing
    By ab56452001 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-03-2006, 10:42 AM
  5. Towing with a vs ute
    By melbdan in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-06-2005, 10:50 AM
