Results 1 to 7 of 7
Thread: VY clunk from rear
    2002 VY SS Ute 5.7
    Aug 2006
    Default VY clunk from rear
    Hey guys just bought a vy and when i go over any form of speed bump or bumps i get a clunk coming from the back, i had the similair thing with my vt and it ended up being sway bar link pins rubber housing or something. The mechanic said it was common in the VT is the VY just as prone to that or would it be something else??
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    if its a series 1 its still got bushes on the top of the stabilizer bar... series 2 got the ball joints tops and bottom
    check your rear shocker bushes cos they can sometimes be squashed and cause a knocking sound, could also be your exhaust has shifted towards the tailshaft from a stretched mount or something similar...
    2002 VY SS Ute 5.7
    Aug 2006
    2002 VY SS Ute 5.7
    Aug 2006
    its definatley only when i go over a bump at speed, shockies maybe? springs? i couldnt see anything unusual under there. its only got 17's and is only lowered with lows not superlows.
    vy ss commodore 5.7ltr
    Jul 2006
    yeh iv got a simmilar noise from the rear in my srz1 vy ss, couldn't see anything broken or worn underneath, i'm thinking rear shocker with mine, its on the l/h/r, was thinking a wheel bearing, but i'm pritty sure mines a shocker, just saveing up my money to put lowered suspension in it all round, start of the year bad time with b'days and rego etc, so middle of the year will lower it, change the suspension bushes in the rear and see what happens, hopefully all good then.
    davey g-force's Avatar
    davey g-force is offline I'm a sceptic...
    Phantom MY09 VE SSV A6 & Holden Cruze CDX M5
    Sep 2005
    "...the winner is..."
    Quote Originally Posted by younglion View Post
    Has your car been up on a hoist lately? Sometimes when the weight is off your rear wheels / suspension and you've got lowered springs, the spring can pop out of place, causing weird noises from the rear.
    It happened to me a while ago after getting mine serviced at Holden. It's a simple 2 minute fix. Just a thought anyway - worth checking out...
    Quote Originally Posted by CSP (aka Rufys) View Post
    Look, all the update is going to be is like going from VX to VY or VY to VZ. Same car with different front/rear ends and updated interior. But it will be the VF, not the VE II.
    VT S
    Jan 2005
    Yeah I had a knock recently, check your bottom shocker bolts, my left side was tight but not tight enough & obviously stilll allowed for some movement.
    all good now
  1. Clunk noise in rear end...
    By Hairy Eater in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 12-03-2009, 05:37 PM
  2. Clunk!
    By Goon in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 07-10-2006, 10:22 PM
  3. clunk!!!!!!!
    By spacattack in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-05-2005, 01:25 AM
  4. clunkity clunk clunk
    By webbo1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-03-2005, 12:30 AM
  5. Vb *clunk*
    By psykore in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 18-10-2003, 08:24 PM
