Results 1 to 16 of 16
Thread: Interior door trim.
    2002 VY SS Ute 5.7
    Aug 2006
    Default Interior door trim.
    hey guys looking for a thread about removing interior door trim so i can change the stock speakers, and i cant find one? im sure i saw one here before has anyone got a link? for a VY BTW
    Lumps of cheese's Avatar
    Lumps of cheese is offline Who wants chowder?
    MY08.5 VE V8 CALAIS/2010 Hilux SR D4 Dual cab 4x4
    Boulder Crusher Champion! Balloon Park Champion! Action Fish Champion! 501 Darts Champion! Frogger Champion! Jungle Kid Champion!
    Nov 2005
    Warrnambool
    2002 VY SS Ute 5.7
    Aug 2006
    thanks mate! so there is no clip behind the window winder like my VT had??
    Nov 2005
    Warrnambool
    Ahhhh, do you have power windows?
    Those instructions i sent you were based on power windows.You would still have the clip if you've got winders.
    VY Exec Wagon
    Oct 2007
    Frankston
    Quote Originally Posted by juzo View Post
    Those instructions i sent you.
    reckon you could just post them up? im interested in how to remove it aswell.
    Nov 2005
    Warrnambool
    Quote Originally Posted by Conkster View Post
    Here you go...
    There are threads here on it but basic rundown is as follows,
    Undo the screws around the outside of the trim also along the bottom as well.
    Grab a small flatblade screwdriver and gently remove the red section of your door lock, this will allow your lock to come free, undo the screw behind it and remove the rest of the lock trim.
    Use your flatblade to also remove the plastic grommet covering the screw for your door handle.Undo the screw for your door handle and remove the handle, it will still be attached to the arm but pulling it out on the right angle will free it.Undo the screw behind the handle, don't forget this one as some do!
    Remove the plastic air vent (based on front door) in the corner, this is just held in by a plastic clip so be gentle with it.
    You should be able to free the skin now, having your window down makes it a bit easier, pull the skin toward you from the bottom and then lift up and your skin should be free.Reach around the back and disconnect the plug for the mirrors and your skin will be completley off the car.
    This is a rough guide so take your time.I'e done heaps now and have them off in minutes so they're fairly straight forward, just take notice of how everything comes off and you should be sweet.
    __________________
    CANYONERO's Avatar
    CANYONERO is offline Likes Cheese...
    V8 6spd wif MOMO leavaa.
    Mar 2006
    Country SA
    i was so aprehensive about ripping the door trims off in the VY but once i got stuck into it i found it easier than the VS to remove. so relieved.
    VYII SS 5.7 LS1 T56
    Jul 2005
    does anyone have any pics for this procedure? im looking to do this soon aswell and dont wanna ruin anything
    Nov 2005
    Warrnambool
    Quote Originally Posted by bluethunder_69 View Post
    I'm doing a speaker install on my ss on friday, i'll take some pics and post them up for you over the weekend.
    VYII SS 5.7 LS1 T56
    Jul 2005
    Nov 2005
    Warrnambool
    VYII SS 5.7 LS1 T56
    Jul 2005
    thanks mate very informative. are those clips on the door demister vents easy to break?
    Nov 2005
    Warrnambool
    Nah they're pretty robust.You just gently pull it outwards and it'll come free.
    VYII SS 5.7 LS1 T56
    Jul 2005
    like outwards away from the door or pull it off at an angle away from the door?
  15. #15
    Nov 2005
    Warrnambool
  16. #16
    VYII SS 5.7 LS1 T56
    Jul 2005
    cheers mate
  1. VX Front door trim (interior)
    By El Barto in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-07-2010, 04:12 PM
  2. Removing interior door trim
    By Mavtd in forum VY Holden Commodore (2002 - 2004)
    Last Post: 20-09-2007, 08:10 PM
  3. Remove interior door trim??
    By Low_VX_Taxi in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-03-2007, 10:06 PM
  4. Removing interior roof trim?
    By ncielens in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 19-11-2006, 08:04 PM
  5. wtb vn/vp interior trim piece
    By na3point8 in forum Swap / Wanted to Buy / Trade
    Last Post: 04-03-2006, 04:17 PM
