Results 1 to 5 of 5
Thread: Problems??
    adamc11 is offline Donating Member
    VY SS
    Feb 2008
    E. & W. Suburbs Melbourne
    Default Problems??
    Hi guys,
    I just got my 03 VY SS yesterday, and i have a few questions about it... i'm not sure if any of the things i'm noticing are normal for holdens or not? This is my first holden
    1. The diff clunks at times when i clutch out
    2. The powersteering is fairly noisy. My friend has an 04 caprice, and hers isn't as noisy, but still has some noise. I checked my power steering fluid and it is black! Hers is yellow-ish. I think i also noticed a little thing floating on the top of the fluid. Is this normal?
    Thanks,
    Adam
    maginoodle's Avatar
    maginoodle is offline Donating Member
    vy series2 ss crewman
    Apr 2006
    definately get both probs checked.
    diffs are a common prob, i need to get mine replaced but am waiting until i can go without my crewy
    heres my ride, i know its not much but its mine
    http://forums.justcommodores.com.au/...-ss-crewy.html
    and heres my new project
    http://forums.justcommodores.com.au/...ml#post1104629
    MY 9.5 SSV Sportswagon M6 & 08 prado D4D GXL M6
    Nov 2005
    Bushfield, Vic
    Try when you are changing gears take revs upto about 2500-3000rpm and see if clunk is still there. Mine seems to do it at low revs more but bring revs up a bit and its as good as gold. These things dont use anymore fuel if you use more revs between changes than if you change earlier allowing engine to labour.
    Try it and see how you go.
    [CENTER][URL="http://forums.justcommodores.com.au/showthread.php?p=490264#post490264"]
    VY SS
    Feb 2008
    Hi guys, just an update it isn't the power steering fluid that is black, it's the brake fluid... which i think is still not normal.
    Also, the diff does do it more at lower revs.
    davey g-force's Avatar
    davey g-force is offline I'm a sceptic...
    Phantom MY09 VE SSV A6 & Holden Cruze CDX M5
    Sep 2005
    "...the winner is..."
    The diff problem is quite common. I had mine replaced under warranty at only 40,000 km! Didn't cost me anything, but it was an $1100 exercise they tell me.
    If it's anything like mine, it'll get a lot worse trust me!
    Quote Originally Posted by CSP (aka Rufys) View Post
    Look, all the update is going to be is like going from VX to VY or VY to VZ. Same car with different front/rear ends and updated interior. But it will be the VF, not the VE II.
  1. VP Problems
    By SteakKnives in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-02-2009, 08:06 PM
  2. Problems
    By MeR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-01-2007, 12:43 PM
  3. ignition problems or starting problems
    By Vs-AclaimII in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-10-2006, 04:55 PM
  4. Some of my VR problems..
    By puncy in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-01-2005, 04:41 PM
  5. vk problems
    By annette in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 22-08-2004, 06:14 PM
