Results 1 to 5 of 5
Thread: getting a service
    VY 03
    Aug 2005
    Default getting a service
    Im getting a service in 2 weeks. Just found out one of my bearings is making a noise so it will need to be replaced. And my computer is out i think im getting 15.5l 100km Oh and sounds like the front shock is gone. Just wondering how much a shock and bearing are these days. Rough idea
    VY 03
    Aug 2005
    Asked a mech today said bearings are pretty cheap. Not sure on a new shocks
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    Front or rear bearing? Rears are not that easy to replace (I suspect you need some form of press or puller) and the fronts, whilst reasonably simple to remove, would be pretty expensive, as they are a sealed unit, comprising the bearing, hub and "spindle" and the anti-lock braking ring. Big bucks at either end - how's your warranty?
    VY 03
    Aug 2005
    I meant engine bearing my bad sorry. Thats to do with the main drive belt And front shocks need to be replaced.
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    Quote Originally Posted by hN! View Post
    the pulley bearings, that the serpentine belt runs on,
    you will need struts (different form of a shock, houses the spring aswell) for the front
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
  1. VZ Service - Is this okay?
    By Swandevil in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 10-05-2007, 08:21 PM
  2. 150 000 km service
    By HVXII in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-12-2006, 10:59 AM
  3. 15K service
    By New2Holden in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 20-08-2006, 10:40 AM
  4. Service - How To
    By vn_calais in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-09-2005, 10:39 PM
  5. 20K service?
    By stew7700 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 12-09-2005, 09:53 PM
