Results 1 to 24 of 24
Thread: vy senator/hsv binacle and gauges?
    vy ss commodore 5.7ltr
    Jul 2006
    Default vy senator/hsv binacle and gauges?
    just wondering if anyone has fitted the vy senator/hsv binacle to there commodore/berlina/calais/s or ss, and if so how did you do it and was it relativly easy? also how much did it cost and what parts did you need?
    thanks in advance, looking at it for my ss, was told its bolt in, plug to plugs already there, but looked behind the dash trim and there was just air vents, no extra wires. any advice and help greatly appreciated.
    adamc11 is offline Donating Member
    VY SS
    Feb 2008
    E. & W. Suburbs Melbourne
    Hey i'm interested in this too.
    I've also noticed that there are 2 types of gauges, ones for cars with climate control and ones for cars without climate control, so be careful which one you buy.
    VY SS
    Feb 2008
    Fekason is offline Fekason
    MY11 VE Series II SV6 Manual
    Mar 2005
    Penrith NSW
    minux's Avatar
    minux is offline Infidel Bear
    300rwkw FG G6ET/2011 Sti Spec R Hatch
    Mini Putt 2 Champion!
    Feb 2005
    The HSV gauges are about $600 or so lol. Very expensive. best off buying 2 LS1 scan gauges. Worked a treat for me and its a fairly easy swap over.
    "Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind."
    - Theodor Seuss Geisel
    Jul 2006
    what are the 2 ls1 scan gauges?
    i was thinking of maybe getting autometer gauges instead and a binnacle to fit or the hsv binacle and autometer gauges to fit, but would realy like to get the hsv ones to go with the dash as its a red dash and green back lit as ud beaware. but don't mind useing autometer instead, though would like to keep the factory type look/feel on the inside. but the auto meter sounds like the cheaper and easier way to go at the moment. and if i had a s/c later on to the gen3, id have to go auto meter for the boost gauge as i don't think holden/hsv would have one of these.
    any thoughts?
    its non climate control.
    one of my dads mates put the gauges like in the bagt falcons into his ba xr8 ute in the same spot, looked awesome, but he used a different brand of gauges that have a blue background and orange needle to go with the dash, as they were cheaper and looked heaps better, plus ford wouldn't sell him the gt ones at the time.
    minux's Avatar
    Feb 2005
    Jun 2004
    brisbane
    i got the binnacle from capa,about $200 genuine hsv.i put autometer gauges in mine.a word of warning,the lighting in them is crap.mine is a vy berlina series 1 so had no harness.got my local auto electrician to wire it all up.$180.you will need an adaptor for the sender unit to mount to the oil pump,either genuine hsv or the existing one can be drilled & tapped.you can also attach to a t piece at the back of the block i believe but it is a bit of a tight squeeze i'm told.
    heres a pick of mine
    Attached Thumbnails Attached Thumbnails vy senator/hsv binacle and gauges?-gauges.jpg
    White S2 LX Captiva Diesel
    Oct 2005
    Here's the main website for aeroforce it says to email them first if ordering for aus cars.. Interceptor OBD2 data stream gauge and scan tool by Aeroforce Technology
    from what i gather they simple plug and play items.. Also dont get a VZ binacle as I believe the wholes for the gauges are smaller then the scan gauges are..
    Jul 2006
    that looks awesome warrick, i like that, yeh i might do that, so the lighting for the gauges isn't that good?
    i had autometer gauges on another car, but it was a vk and they sat under the a groupa bonnet scoop, and they came with it so i just asumed it was cause they were old, but if they are dull i know what u mean, might have a look into it and see what its like i know there not as bright as the dash lights, thanks for the info and help.
    minux's Avatar
    Feb 2005
    Quote Originally Posted by cpbait View Post
    Why waste your money with crappy looking gauges. Seriously, buy a scan gauge you will not regret it...does so much more than a piddly voltmeter and oil pressure or whatever you decide to put there.
    Jul 2006
    had a look at those gauges, they look realy good, i emailed them to contact me, they look like a gwd idea and especialy for performance tunning later on too and knowing what everything in the engine bay is doing.
    Jun 2004
    brisbane
    just depends what you like.i'm not a fan of digital gauges & these match the dash gauges quite well.but yeah the lighting is quite dull.i had some spitfire gauges in my old vt which lit up very good,but these look classier i think.you may think there "crappy" minux but as they are in my car you dont have to like them & they suit my needs.thats why we're all individuals.
    cheers
    warrick
    minux's Avatar
    Feb 2005
    Quote Originally Posted by warrick View Post
    cheers
    warrick
    I didn't mean crappy int hat sense, I meant in comparison. When you have the option to use the gauges you used or an OBD setup, you would take the latter.
  15. #15
    VY SS
    Feb 2008
    I prefer the look of warricks gauges as opposed to the digital interceptor ones, but yes fair enough the interceptor give you a lot more options...
    Just one question about the interceptor gauges, will the LS1s support all the features the interceptor is capable of that is listed on this site: AeroForce Interceptor Gen II Scan Gauge - GM OBD-II Vehicles [AF1-OBDII] - $259.00$239.00 : MarylandSpeed.com- Your First Stop on the Way to Performance!
    Thanks
  16. #16
    minux's Avatar
    Feb 2005
    Quote Originally Posted by adamc11 View Post
    Thanks
    Prettty much yup.
  17. #17
    VY SS
    Feb 2008
    Hi warwick.
    Where is capa? Phone Number? Website?
    I rang jhp vehicle enhancements and they quoted me $880 for binacle and gauges (genuine hsv) yikes!
  18. #18
    Doctor Bob's Avatar
    Doctor Bob is offline Grandpa
    VT V6 Exec & VN V6 Exec
    May 2004
    Mornington Peninsula
    Hi warwick.
    retail price on genuine guages is about $600
    i can get a set for about $400 if you want them?
    Rob
  19. #19
    Jul 2006
    yeh i rang jhp the other day and got quoted $880 as well for genuines, i nearly dropped the phone, i knew they were expensive, but didn't think they were that much.
  20. #20
    2002 VY SS Ute 5.7
    Aug 2006
    will the scan gauge work with a VY executive or does it have to be a HSV? and also where does it plug into? looks pretty cool being able to track all that info.
  21. #21
    Oct 2005
    From what i read the scan gauges plug straight into the computer, shoudl work on all commodroes I think I'vew been after a set for ages for my SS but that will have to wait til after the edit is done... more power first nice gauges later..
  22. #22
    Jul 2006
    here's the email i got back, will help answer some of the questions to how it plugs in etc.
    Hi Ben, thank you for your enquiry. I do not sell the pods unfortunately but may look at this down the track.Cost for a dual setup is $580 delivered to your door. This will show 4engine parameters at once (or more if you cycle a gauge) and allow you toprogram two warning lights, one for say a shift light and the other for oilpressure warning or over temp etc. They are the easiest gauge to wire up as you just plug straight into theOBDII port and away you go, no other connections as it gets power and alldata from the computer. In relation to your SC, I don't think it will read this natively as yourcomputer was not originally intended for a supercharger fitment although youcan buy an aftermarket boost sensor and wire up to one of the two analogueinputs to give you boost. I hope this information helps, feel free to ask any further questions. Regards, Robert Mellor.XTreme Auto Gauges Australia Pty Ltd
  23. #23
    sp001in's Avatar
    sp001in is offline vyma100
    MALOO R6
    Jul 2005
    QLD
    interesting, I heard you can order the binnacles for $80 same look as hsv ones but screw in. (thats dodgy), hsv ones are $200 for the binnacle, I have an autometer air/fuel ratio gauge and I'm gonna buy a vac gauge to put beside it. gauges are around $120 my air/fuel was $160.
    Check out my build <---Click me
    Now sporting ASR audio interior lighting and stereo mods, and MACE induction mods.
    Need your computer tuned, or dash calibrated??? Want your PS3 fixed, or wish to prevent the YLOD?
  24. #24
    VY1 HSV Clubsport R8 M6
    Oct 2005
    Western Subs Melbourne
    Hi warwick.
    Capa are in Adelaide and can be found on the web at Centrifugal Air Pumps Australia
    To all the BA's I've blown the doors off, GIVE UP!!!
  1. New Pod Gauges
    By DA_VZ_UTE in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 02-01-2008, 05:29 PM
  2. Gauges
    By krazyboris in forum VY Holden Commodore (2002 - 2004)
    Last Post: 11-03-2007, 04:45 PM
  3. vdo gauges
    By markandsam in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 12-11-2005, 10:06 AM
  4. My Gauges
    By ozzie_online88 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-10-2005, 12:03 PM
  5. gauges
    By mistermeena in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-06-2005, 06:23 PM
