Hi all,
I want to do an oil change on my V6 never done one before, its always been at the dealers for that, my question is where do i find the sump plug on these engines.
Peter
you will see the base of an alloy pan behind the radiator, it has lines casted into it, sump plug is on the passengers side of the sump, oil filter is ryco z154, when you replace the oil filter make sure the old o-ring comes off and when you tighten lubricate the new filters o-ring, dont over-tighten the filter, just till it stops than 3/4 of a turn is all its needs
EASTERN CREEK JCNSW 2009
Originally Posted by Commydoor
