hi guys i just bought a VYII S manual and the reverse lights dont work. i have checked the bulbs and plugs they are fine. i even used a test light to check if there is power coming from the loom to the lights but there is no power coming thru the reverse light wire when the car is in reverse.
does any one know what might be wrong?
any help would be good
cheers
Ben
have you checked for power at the reverse light switch on the transmission? i guess you checked the fuse? under the steering wheel
EASTERN CREEK JCNSW 2009
Originally Posted by Commydoor
