Results 1 to 14 of 14
Thread: Cracked Radiator
    VY 3.8 S1
    Feb 2008
    Bris Vegas
    Default Cracked Radiator
    Well this morning I was driving and I could smell coolant (sp?) so I went home and my fiance told me I have a cracked radiator
    Now what do I do? I know NOTHING about radiators!!
    It's a split through the side of it, not through the pipes but the actual radiator itself.
    Is it fixable or do I get a new one? And where do I get them from? And price? .. I told ya I know nothing about them
    KRUPTD is offline VN BT1 5L
    VN BT1 5L,5spd,LSD
    May 2007
    Griffith, N.S.W
    I would suggest replacing the split radiator with a brand new item.The best bet for is to find a local radiator shop who does mechanical work to get them to fit the new radiator then all the work and parts are under warranty if something was to go wrong once your get your car back.
    (KRUPTOR)VN BT1 5L TTB's,MANUAL,LSD
    VY 3.8 S1
    Feb 2008
    Bris Vegas
    Well, I rang a few places up and it's $255 brand new which is the one I'm gonna get but nothing is open until Monday now
    My dad knows how to fit them all in so he's doing it for me.. at least that's good.
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    is that 255 including fitting? that seems a little high to me
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    Silver surfer is offline Banned
    04 VY Executive
    May 2007
    depending on where in the radiator its self it can be welded up for example the top radiator tank on my landcruiser cracked and was welded back up. it is however a special weld.
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    Quote Originally Posted by Silver surfer View Post
    im guessing that had copper/brass tanks on the cruiser, which can be fixed easily, commos have plastic tanks that are crimped on and when they split price wise your better off getting a newey
    VY S Sedan
    Sep 2007
    This is a common fault with VY V6 radiators,the plastic in the side tank was not molded correctly (too thin).It's on the passenger side of the radiator right?
    Get a qualified repairer to fit a new one,and make sure they use the correct coolant and pellets.
    VN BT1 5L,5spd,LSD
    May 2007
    Griffith, N.S.W
    Its a common fault for all commodores fitted with plastic tank radiators to split/crack or bulge in there side tanks.But the most common would have to be VT's in the last month at work we have done 8 radiators in commodore and 5 of them were VT's.
    VY 3.8 S1
    Feb 2008
    Bris Vegas
    Quote Originally Posted by whitey66 View Post
    Yep it is.
    My dad is a qualified and I'm glad I have him because I don't have a clue and wasn't looking forward to paying extra for someone to fit a new one in.
    Is $255 too high ya reckon? Just for the new radiator itself.
    vl?
    Mar 2008
    well you could try an old trick , crack an egg wit some pepper in 2 your radiator.you could try an aluminium weld unless its the plastic bit or best off replacing it,jump on ebay.
    VY S Sedan
    Sep 2007
    Quote Originally Posted by holden_chik View Post
    Yep it is.
    Yeah,I can get a price for you tomorrow (Tuesday) if you like on a genuine one.I'm a Holden Technician with over 16 years experience on Holdens alone,so i've seen a few of these let go.Some with as little as 5,000kms on them.Is it for an auto or a manual?
    Edit:Yeow!! $467 for genuine.I'd get one from Ebay if I were you.They go for around $180 PP.
    VY 3.8 S1
    Feb 2008
    Bris Vegas
    Woah $467!!!
    Well, I ended up getting one from the radiator place up the road from me. I rang a few places and some went as high as $380 for just the radiator so $250 was the cheapest I found. I brought the radiator, tubes, coolant, thermstout (sp?) - I pulled that out to keep the car running while the radiator was cracked, I had to get to tafe somehow and some other things, all for $350.
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    Woah $467!!!
    350 for all that aint that bad i guess, good to see your on the road again
  1. VR A/C Condenser Nut Cracked
    By Bilbs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-03-2008, 12:56 AM
  2. radiator cracked @ servo yesterday
    By cxcxcxvcvcvc in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-09-2007, 12:03 PM
  3. radiator cracked
    By S.T.S in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-11-2005, 05:13 PM
  4. Brass radiator VS Aluminium Radiator
    By Gs VS in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-11-2005, 10:31 PM
  5. cracked sump
    By cizocizo in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-08-2005, 12:26 AM
