Results 1 to 23 of 23
Thread: Diff on Ground
    VY Acclaim
    Nov 2006
    Default Diff on Ground
    Hi,
    I have a problem.
    I have Super Low springs in my VY2 SV8.
    When I have even just one person in the back and a go over a small-medium bump in the motorway (crappy NZ roads) the back drops down as you would expect after the bump after which there is a loud bang when the diff hits the ground.
    When the back of the car is full, it does it on small bumps at 50ks...
    My question is can the diff be raised or have some guard installed or does the car need to be raised???
    Thanks
    Adam Ant
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    if the diff hits the ground then you must have no springs in the back at all cos it should be sitting on bumpstops... so id be checking if they are still connected to the chassis before anything
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    Quote Originally Posted by Peanuts Inc. View Post
    Close.... If the diff hits the ground then the wheels must have fallen off and the solution should be self evident
    Reaper
    VY Acclaim
    Nov 2006
    nah, definately not hitting bumpstops and the springs are definately in, i dont think they are captive at full extenstion though, if you say it cant be the diff then what else could it be because it definately sounds like it and the bottom of the diff houing has some large scrape marks along the bottom
    thanks
    adamant
    Boonz's Avatar
    Jul 2005
    it would be the bumpstops hitting... the diff would have scrapes from wogcrawling over speedbumps cos when you go on angles it drops the diff down when the first wheel is on level ground
    Reaper's Avatar
    Aug 2004
    Exhaust, subframes, anything else under there..... Look for the bit with the dent.
    Reaper
    VY Acclaim
    Nov 2006
    oh really, would that also make the huge loud noise???
    also another problem which may or may not be related, when giving it some boot around corners i heard no huge noises but apparently there were sparks coming out the back of the car...
    Boonz's Avatar
    Jul 2005
    that might be the exhaust
    i suggest you raise your car up and use higher load rated springs so it doesnt bog down when you give it some boot
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    dosnt the exhaust on the vy's loop over the rear suspenion and the drive shafts, theres some pretty close parts there so i would check out if the exhaust has been hitting with the suspension
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    Reaper's Avatar
    Aug 2004
    VY Acclaim
    Nov 2006
    i currently have superlow king springs, what would you suggest???
    also am going to be havn approx 120kgs of sounds in the boot soon, do you think some low kingsprings would do the job?
    Reaper's Avatar
    Aug 2004
    Quote Originally Posted by AdamAnt View Post
    120kg is a lot of weight to cart around all the time.... I'd look at an uprated spring rate myself.
    Reaper
    VY Acclaim
    Nov 2006
    the problem is that it dosent look very low, but something must be at fault???
    could it be the exhast hitting either the ground or some other part of the rear suspension/frame etc etc
    VY Acclaim
    Nov 2006
    Boonz's Avatar
    Jul 2005
    i wouldnt use kingsprings for heavy duty purposes.... i know pedders does a set of lowered heavy duty springs.
    i just dunno what height it sits at
  16. #16
    VY Acclaim
    Nov 2006
    oh really thanks, how would i go about getting pedders springs in New Zealand or would something like dobi make a similar spring???
    thanks
    adam ant
  17. #17
    Boonz's Avatar
    Jul 2005
    oh.... ask a suspension place if they do heavy duty springs cos i didnt see that your in NZ
  18. #18
    VY Acclaim
    Nov 2006
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    thanks
    adamant
    It could be that the springs are about 150 mm too short, too. Brother, when the arse of the car starts bouncing on the tarmac, get rid of the springs and start again.
  20. #20
    Nobody Actually's Avatar
    Nobody Actually is offline luxo barge
    VS s2 Caprice 5l = slow
    Aug 2005
    Queensland
  21. #21
    davey g-force's Avatar
    davey g-force is offline I'm a sceptic...
    Phantom MY09 VE SSV A6 & Holden Cruze CDX M5
    Sep 2005
    "...the winner is..."
    Heaps of people have super lows on their VY's and don't have any such problems. Sounds like your problem is related to something else, as suggested.
    Get it up on a hoist and have a good look...
    Quote Originally Posted by CSP (aka Rufys) View Post
    Look, all the update is going to be is like going from VX to VY or VY to VZ. Same car with different front/rear ends and updated interior. But it will be the VF, not the VE II.
  22. #22
    adamc11 is offline Donating Member
    VY SS
    Feb 2008
    E. & W. Suburbs Melbourne
    Could someone with superlows post some pics so i can see how it looks. Thanks.
  23. #23
    lc torana. vn v8. ke30.mazda 1300.
    Mar 2006
    could be the muffler or something hitting the ground or something hitting the floorpan .. just crawl under and see if anythings dented or scratched
    wrecking VL COMMODORE 5 speed
    FOR SALE : supra 5 speed box suite holden v8 $800
  1. Best Spot to Put Ground
    By tfacter in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-02-2008, 06:33 PM
  2. Ground Point
    By calais_cruzin in forum Car Audio
    Last Post: 14-02-2007, 03:59 PM
  3. Door ground!
    By HoZy in forum Electrical Wiring / Questions
    Last Post: 18-04-2006, 07:56 PM
  4. Ground Control
    By soyaman in forum Jokes/Humour
    Last Post: 25-02-2006, 10:52 PM
  5. Ground Wire in VR/VS?
    By SMIT in forum Car Audio
    Last Post: 17-01-2006, 11:21 PM
