Results 1 to 8 of 8
Thread: Hole in driver seat upholstery
    VY Berlina
    May 2005
    Angry Hole in driver seat upholstery
    Had my car in for a service today. When I went to pick it up I was very upset to find a hole in the upholstery on the right hand side of the drivers seat. Looked a bit like someone had stuck a screw driver through it. Holden say that the foam in my seat has collapsed and that a part of the seat base has been rubbing the fabric and caused it to rip. After examining the seat I can see how this could have happened however it's really frustrating that they managed to actually make it rip when I have been driving around in the car for over a year with no problems. Someone must have jumped into the car really fast or knelled on the side of the seat
    Apparently it is a common problem, has anyone else had this problem?
    CANYONERO's Avatar
    CANYONERO is offline Likes Cheese...
    V8 6spd wif MOMO leavaa.
    Mar 2006
    Country SA
    im about to buy a SV8 and it suffers from the same disease. i wonder what it would cost to fix.
    EvoVIIIJDM is offline Got Evo?
    Evo VIII JDM
    Nov 2005
    nicko's Avatar
    nicko is offline Carbon Positive - DO IT!!
    75 cruiser ute
    Sep 2007
    sa
    every car has this problem after a while. call an auto trimmer and they will hook you up with a fix it. i should say that the entire seat trim WILL NOT have to be replaced as they can just re-sew it underneath saying you some coin. I would say 100+ to fix it
    no longer a hoon by association - the commodore is gone
    VY Berlina
    May 2005
    Here is a pic, probably too bad at this stage to get sewn up I reckon.
    The seat surround(the plastic with the electric seat switch) has also snapped off as a result of the same problem, I was given a rough quote by holden of $400-500+labour to replace the seat surround, upholstery and trim.
    Paddy
    Attached Thumbnails Attached Thumbnails Hole in driver seat upholstery-dscf1542.jpg
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    spaddyj
    From your picture, it's pretty obvious that the seat base has sagged. The side bolster on the seat base is showing typical signs of the foam below the upholstery collapsing = pretty typical for all Commode seats after a fair bit of use. It wouldn't be much use just having the upholstery repaired = you really need to have the seat base foam rebuilt too. This is still a simple job and you can save a few bucks by removing the seat and dismantling it, and just taking the seat base to the upholsterer. They can rebuild the foam and repair the worn cloth and its a simple matter of re-assembling the seat yourself.
    With regards to the plastic side trim,they can be purchased for around $60 new. I have recently fitted the passenger seat with electric tilt and lift and had to replace the plastic trim with one designed to accommodate the switch. Pity it's the wrong side - it's like new.
    Regards
    pj
    adamc11 is offline Donating Member
    VY SS
    Feb 2008
    E. & W. Suburbs Melbourne
    Quote Originally Posted by VYII BERLINA View Post
    Was this easy to do, and how much did it set you back? Thanks.
    Calaber's Avatar
    CG Captiva SX
    Nov 2007
    Adamc11
    It was extremely tedious. I bought a well used VT drivers seat for the motors and lift mechanism, but when I removed the VY passenger seat, I found that the design of the seat bases had changed a lot since the VT. I had to:
    1. swap over the rear mounting brackets,
    2. remove and reshape the metal bracket holding the wiring clips to the rails, 3. swap that bracket over to the opposite side,
    4. remove the seat belt mounting bracket from the VT seat and replace it with the VY one, which had to be slightly modified to fit the VT rails,
    5. make up a wiring loom to cross over the floor from the drivers seat connection.
    6. swap the wiring connections on the motors so that the drivers side operating switch would operate the motors in the proper direction
    7. modify the mounting arms so that they were mounted further towards the centre of the seat, to align with the VY mounting holes
    8. make up mounting plates to adapt the VT arms to the VY seat base.
    9. fit a new left hand seat side trim, to accommodate the switch. This is an HSV part, as Holden never offered the four way power seat on the VY, but HSW did.
    10. purchase a black switch button as the VT trim was grey.
    Probably a few other things I've forgotten. The bottom line is it was too much trouble and would have been a lot simpler to have adapted a VY drivers seat base. I figured the old VT seat would be cheap (it was - $50) and a VY seat would be too expensive. I also figured the power seat mechanism would be too expensive to purchase new.
    Total cost was around $150, total time around ten hours.
    At least it looks like a factory installation and the other half is happy. (happy wife - priceless!)
    Regards
    pj
  1. Foam falling out of driver seat???
    By coroman in forum VY Holden Commodore (2002 - 2004)
    Last Post: 26-11-2010, 08:57 PM
  2. Replacing Seat Covers (Upholstery) Help.
    By xtrmty in forum General Discussion
    Last Post: 23-03-2008, 12:26 AM
  3. upholstery materials
    By Philthy in forum General
    Last Post: 08-12-2007, 08:03 AM
  4. WTB: VN Calais Driver Seat (Pics)
    By dawg in forum Swap / Wanted to Buy / Trade
    Last Post: 03-04-2007, 09:59 PM
  5. VY II Driver Seat Belt Reminder Alarm
    By neon_crossing in forum Electrical Wiring / Questions
    Last Post: 22-02-2007, 12:36 AM
