Results 1 to 7 of 7
Thread: Noisey V6
    VY Berlina Wagon
    Mar 2007
    Default Noisey V6
    Hi Guys, my vy v6 is a little noisey , its done 165000 k's . What oil would be good to quiet it down
    Peter
    vy series 2 v8 berlina
    Dec 2006
    Quote Originally Posted by Loupy31 View Post
    Peter
    you could try a thicker motor oil when you change your oil next. eg a 10/60 viscocity range.
    vy ss commodore 5.7ltr
    Jul 2006
    is it deffantly a engine rattle like lifters or a pulley type noise? i know the harmonic ballancers are common on going on these, as i had the same problem in my vr, i know different motors, but same type ballancer, check the main crank pulley, the big one at the bottom of the engine, u'll know which one when u see it, it has a rubber center, check that there is no cracks or rubber missing, also if this is ok and its in the engine, like lifters, etc, check the oil level, might be low too, and if its a ticking top noise at the very top of the motor like on top of the manifold could be just noisy injectors, common too.
    VY Berlina Wagon
    Mar 2007
    When you give the engine a bit of a rev then as it goes back to idle there is a little bit of noise from the rocker cover area..not a great deal but its there, when your driving along its perfect no problems at all, I am using 5w 30 castrol edge.......wouldnt 10 w 60 be too thick or doesnt it work that way.
    Peter
    FG XR6T Ute manual
    May 2007
    Brissy
    ive got a 10w50 in my vz and i think thats a little thick. but im not sure about the eco's
    Chuck Norris destroyed the periodic table, because he only recognizes the element of surprise
    Jul 2006
    yeh i'm useing the castrol edge 5w-30 in my vy ss and its good, i have a slight lifter noise at cold start for a min or two then its ok, used to be all the time, untill i switched to castrol edge, so you useing a good oil, mines done 159,000km's
    nicko's Avatar
    nicko is offline Carbon Positive - DO IT!!
    75 cruiser ute
    Sep 2007
    sa
    mate, do yourself a favour and buy some "Moreys oil stabilizer" its in a white a red container and comes in 1L bottles $18 i think, it works a treat
    no longer a hoon by association - the commodore is gone
  1. SV6 Noisey on startup!!!
    By Co_cker in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 14-02-2007, 09:25 PM
  2. noisey fan
    By VL Berlina 5speed in forum VL Holden Commodore (1986 - 1988)
    Last Post: 29-06-2006, 11:35 PM
  3. Noisey Fan
    By vt busso in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-10-2005, 10:09 PM
  4. noisey v8
    By vrclubbie in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-12-2004, 09:54 AM
  5. Noisey Manifold
    By wpr in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-04-2004, 12:20 PM
