will a vz ss front bar go stright onto a vy ss. i mean they look the same but knowing holden they are different in some kind of hidden way any advice would be good before i purchase the bar
as far as i know it will fit but u need to change other things like the bonnet so it fits properly.. I've heard that somewhere before. Hope it helps![]()
A Commodore is a passion. Anything else is just a car
you'll have to change the headlights as well because of the parkers will get in the way
i can verify it will fit but u need a vz bonnet for it to look right
cos the bulge in the vy bonnet is lower and spread further apart than the vz, which is higher and slimmer.
Check out my build <---Click me
Now sporting ASR audio interior lighting and stereo mods, and MACE induction mods.
Need your computer tuned, or dash calibrated??? Want your PS3 fixed, or wish to prevent the YLOD?
it is correct a vz bar will not go with the vy bonnet i am doing this conversion and i guarentee it
so if i got the vz ss front bar. i would need a vz bonnet(or vz monaro style bonnet) and headlights without the parker dimple and all would be sweet?
Just curious guys... (a bit off topic)...
Are the vy and vz headlights the same shape and size (except for the parker spot on the vy?). I'm thinking, if they were exactly the same, is it possible to get vz headlights, remove the lens and fit the vy lens? Therefore you would still have your parker bit that fits into the bumper but you would have the vz headlights. You may need to do some extra modifications though. Anyways, is what i'm thinking at all possible?...
The body of the lamp would be different, as it has to align with the parking light. I think I've seen somewhere else that they are actually a different shape at the grille end, with a different angle. In other words, they are not interchangeable.
so will i need vz headlights? or will vy headlights without the dimple be ok?
get vz ss lights they're projector =)
projectors would be nice
the vy hsv's have them tis why i asked if they need to be vz headlights
