Results 1 to 6 of 6
Thread: vyss cluster into vy s
    Mar 2008
    Default vyss cluster into vy s
    hey i was lookin at putting a cluster out of a vyss into my series 1 vy s pac just wanted to get some info on whether or not it will fit, im pretty sure the mounting holes will line up but i just wanna see if the back plug will be the same and what do i have to do to make it go properly if i put it in
    Fekason is offline Fekason
    MY11 VE Series II SV6 Manual
    Mar 2005
    Penrith NSW
    Default Caution.
    If you get a VY SS cluster from the same series, then the cluster will work OK.
    VY and VY II series have different fuel sender units. If you get the wrong cluster, then your fuel gauge will work backwards and the Distance to Empty will be useless. This can be fixed at significant extra cost, but it is much better to get it right the first time.
    Why not go to a HSV cluster with the three window trip computer? That way you get increased functionality as well as the changed background colour.
    VY Executive
    May 2008
    Hi Guys, you can also change the needles and face plate from a VY SS dash onto your standard dash, you only have to solder 2 extra leds for dash illumination, means you dont have any worries about programming. JHP Vehicle Enhancements in Blackburn can do this. Mickymac
    Doctor Bob's Avatar
    Doctor Bob is offline Grandpa
    VT V6 Exec & VN V6 Exec
    May 2004
    Mornington Peninsula
    the dash will fit fine, it will need programming to suit your cars wheel size & airbag configuration.
    the reverse fuel sender issue can be fixed by programming.
    2003 VY Storm
    May 2008
    any one had a fuel sender die ?
    is there a cheaper after market fuel pump
    Holden dealer wants $340 for the # GE170 pump/sender
    mine died when i pulled the bloody handbrake on gettin a slab
    VY S L67
    Nov 2007
    cluster will say SS in the middle?
  1. VYSS346's ...03 VYSS
    By VYSS346 in forum VY - VZ - WK - WL - V2
    Last Post: 25-05-2011, 12:47 PM
  2. do VYSS wheels fit on a VB
    By DO88SY in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 18-01-2007, 11:55 AM
  3. ::---my vp cal with vyss 18"---::
    By ben k in forum VN - VP - VG - VQ
    Last Post: 17-11-2006, 03:53 PM
  4. VYSS Ute - On Gas
    By tcp000 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 07-09-2006, 10:00 AM
  5. New 19's on my VYSS.
    By DazVYSS in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 15-05-2006, 04:37 AM
