Hey guys Ive been playing around with my car thought id seen oil so i touched where i have put the red arrow in this pic below and got a swab of oilJust wondering what it could be It was in for a service about 3 weeks ago mech said he had seen a small dot and it was a common problem errr... so i check myself and by the photo i can see more. I have a 3 year warranty on drive parts gearbox engine etc. So if someone has a fair idea please tell me straight. Here is the pic.
Could it be the rack some how ??
it looks like a trans leak to me, from where the photo looks to be taken.
We got rep back, yaaay!
abuse your warranty to its maximum potential. Go and see them about it
Yeah thats what im thinking if they dont do anything Ill just drive it untill it goes. Then they will have to replace it.
most likely an engine rear main leak, vy ecotecs still did it
EASTERN CREEK JCNSW 2009
Originally Posted by Commydoor
Ive got that exact same leak, i figured its probably the rear main seal. i havent really worried about it, its not pouring out.
Yeah well Im not getting major drips on the ground. But still im going to say something about it when they replace my shocks.
Ok they rekon that the leak isnt under warrnty some how :S So im in dispute with the car company atm Just a question is it hard to change that seal? It looks like it is considering the gearbox would have to come out. Plus they said it would take them 2 hours to replace my back shocks and 1 n half to do my brake pads at $99hr I can do this myself but i would then void the warrinty.
I did not buy the car brand new Its the warrinty that i got from the car yard. They say its an oil leak and have told me so if that part breaks they wont cover it, its bs.
3.8's were notorious for this leak, it's the rear main engine seal. Haven't checked but was told by a mechanic once that to change the seal was a reasonably big job compared to the amount of oil you will actually weep out over the car's life. My VY hasn't started doing it yet but the VR I had (for 2 years) never once dropped oil on the drive, the leak was that minimal. Give it a wipe and see how long it takes before a substantial amount reforms, if it is quite bad then go the warranty route. As for $99/hr for a pad changeI suppose because I've always done my own this sounds like a rip off to me. $40 odd bucks ($NZ) for a set of pads that do both sides & the same at the other end then 30 minutes of my time and it's done.As for voiding the warranty if you do it, sounds to me like the car sale's trying to pull your todger.
Mate, they are ****in in your pocket big time!!!
2 Hours to change out rear shocks!!!!! That is B/S !!!!
They want $350 labour to change out shocks and pads alone!!! NO WAY!
If they are a proper workshop and cant do it in half an hour they should not be in buisness!!!!! Even if they quoted 1 hour for any dramas etc... but 2 hours????? Get out of here!!
They should also be able to change the pads much faster than that!!! But if you add some time to roadtest vehicle and extra bleeding if required, 1 hour may come close!
I would hate to know how long it will take them to do ur rear engine main leak!
Good luck!
Looks more like a sump gasket to me.Also the sumps from VT's onwards also had problems of cracking and also being porus (leaking oil).Remember replacing a rear main seal is a big job you have to remove the gearbox.So you would have to allow some time roughly 3 to 5 hrs.
(KRUPTOR)VN BT1 5L TTB's,MANUAL,LSD
OK Im getting my shocks and pads done for $150And the leak going be coming from my right rocker side I can see it going down near the exhaust area. So it must running down and making it look like the rear main.
