Results 1 to 23 of 23
Thread: Supercharger dies
    eXcon's Avatar
    eXcon is offline cyal8r
    Luxury VY 3.8ltr Supercharged 6
    Aug 2006
    Gold Coast
    Exclamation Supercharger dies
    Hey guys, 2003 VY Commodore Exec, 3.8 ltr Supercharged buick.
    Well I just took it for a run and got the supercharger to cut in at approx 4000 rpm, I'd prefer if it cut in a little earlier, but anyhow, it only cuts in for like a second, and then dies almost instantly.
    Can anyone shed some light on this please?
    Any info is welcome and thanks in advance, cheers.
    nicko's Avatar
    nicko is offline Carbon Positive - DO IT!!
    75 cruiser ute
    Sep 2007
    sa
    what supercharger is it? factory?
    no longer a hoon by association - the commodore is gone
    eXcon's Avatar
    Aug 2006
    Gold Coast
    hey thanks for the quick reply, its driving me nuts yes, the supercharger is factory lol, any ideas on what would cause this?
    nicko's Avatar
    75 cruiser ute
    Sep 2007
    sa
    You could have a vacume leak. Check all holes and pipes that lead into and off of the supercharger. With the motor running check the same pipes again and listen for any escaping air etc. Rev the motor to see if this forces air out of a hole/split in a pipe. Have you checked your error codes yet?
    daron's Avatar
    daron is offline wizfiz
    VE SSV
    Mar 2006
    adelaide
    im cvonfused because superchargers dont cut in when at 4000 revs they are on al the time
    how do you knwo its the charger cutting in and out
    what stops how do you know
    have you cheched to see if it hasnt fallen off heheheh
    eurekamad94's Avatar
    eurekamad94 is offline street kiddo
    kitted, tuned, sick pantha VS
    Jan 2008
    qld
    nicko's Avatar
    75 cruiser ute
    Sep 2007
    sa
    eXcon - i think your best option will be to take your VY down to a mechanic or to holden to get them to have a look at your problem. What state are you in?
    eXcon's Avatar
    Aug 2006
    Gold Coast
    Hmm, the hoses sound fine, there don't appear to be any codes in the system, the whole motor does sound a bit airy tho, I reved the car in park but the supercharger didnt seem to kick in at all .. not sure what's on here, a bit lost, man thanks a lot for the replies it really is a help, cheers.
    Edit: Oh, the superchargers are operating at all times ? Hmmm, I wonder why the car dies back at approx 5 thou then...
    nicko's Avatar
    75 cruiser ute
    Sep 2007
    sa
    yes a supercharger is run off the main drive belt on your motor and as a result it is always supplying the car with boost. have you done any mods to the car or has this problem suddenly appeared? did any major event trigger the loss of power or did you just turn it on one day and it was like it is now?
    eXcon's Avatar
    Aug 2006
    Gold Coast
    Quote Originally Posted by nicko View Post
    Hey nicko, state of Queensland, Gold Coast precisely, I'll take it for another spin soon, see if it's not the transmission or something ... last thing i need is more troubles with this car, bought it about a month ago and all was beautiful, recently lost two out of three brakelights (not the spoiler one), and the trac off stays on and cant get it working again, also the cruise control which worked beatifully is now affected by the trac off I believe, thanks for the help fellas, your help is appreciated, believe me
    nicko's Avatar
    75 cruiser ute
    Sep 2007
    sa
    maybe make a post in the qld section asking about a decent mechanic in your area, however most mechanics will do a great job. If you have lost traction control and cruise then you could have an electrical problem. Have you checked the trac and cruise fuses?
    eXcon's Avatar
    Aug 2006
    Gold Coast
    yup checked the fuses, I have a feeling its the brake switch, as I can regain cruise and trac if I start the car with the brake on, but as soon as I lift the foot she's back to trac off again, it's all a bit confusing really :
    may take the car into holden for its 150thou km check soon, last owner skipped the 135thou check and the reminder bugged me so hard, $350 for the 135k service, $150 for the 150k check, so I reset the reminder
    in 600 kays noone will know the difference, and I'll save $200 and get the car serviced by the manufacturer, hopefully that will bring it up to scratch, cheers!
    2x VS
    Jul 2005
    Yeah they are always on but NOT always boosting because they have a bypass valve which causes the intake air to bypass the blower vanes at low revs to improve economy when cruising.
    @eXcon
    I take it you have the plastic cover removed and can see all the hoses and crap hanging off the blower ?
    I think you maybe have one of a few faults
    1. Boost leaks from a blown/damaged inlet gasket.
    2. Vacuum leaks causing the by-pass valve to not operate effectively.
    3. Temp sender or boost solenoid malfunction causing the boost vacuum circuit to be shut off.
    First check the bypass valve actuator isn't sticking and that it's closing when you give the accelerator linkage a quick yank. (The little black round thingy with a linkage at the bottom on the passenger side of blower) It should snap shut quick when you rev the engine hard.
    If there's an air leak in the hoses somewhere there you may not be closing off the boost by-pass valve when boosting.
    On the passenger side head at the rear there is a solenoid which controls the by-pass valve vacuum signal... check all hoses are connected to it.
    If you have gasket leaks they can be tricky to trace down as they may be leaking internally.
    Join up to l67torque. com you can find heaps of info and help there if this doesn't help.
    Cheers,
    Mike
    Disclaimer For The Reader ::
    The information I provide is freely given to ONLY help you with thinking on problem solutions. IT IS NOT a "How To Do It Guide".
    If you read ANY of my supplied information and use ANY of it you must accept and agree to do so AT YOUR OWN RISK
    or do not use the information at all
    I accept NO liability if you damage your or anyone elses property or cause any harm to yourself or others with the information provided.
    I am NOT a Mechanic. You have been warned.
    eXcon's Avatar
    Aug 2006
    Gold Coast
    K took it for a burn up the highway, not only can I feel but I can hear the blower chop in... sa-weeet! I guess I must've panicked, my guess is that the transmission slipped up a gear or something .. it seems like it's working just fine, although I can't be sure until I get it the 150,000 km service in a few weeks. Also, I'm pretty certain that the brake light problem is the brake switch at the top of the pedal under the dash, however the spoiler light is activated when I pedal the brake, just the other two main lights aren't activating, the globes and fuse are all fine so not sure about that one, I just hope it's not the abs module! I want to thank all of the people who posted help when I needed it, I appreciate all of your comments, I thank you all.
    Not quite a datsun..
  15. #15
    eXcon's Avatar
    Aug 2006
    Gold Coast
    Got the switch! Sunday morning, Cheapa Auto Spares Molendinar (Gold Coast), $18.50, that's $10 bucks over priced... my theory is that replacing the switch will re-enable the traction control and cruise control, aswell as fix the rear body braking lights, and if my calculations are correct, when this baby hits 88 mph, you're gonna see some serious ****!
    I'll post back soon, then I'll break it down properly for future sufferers of these symptoms. Stay tuned.
  16. #16
    eXcon's Avatar
    Aug 2006
    Gold Coast
    Update, installing the new switch fixed the cruise control and traction control, but the darn brake lights are still limited to the spoiler
    Wow this is rough, will update soon.
  17. #17
    Doctor Bob's Avatar
    Doctor Bob is offline Grandpa
    VT V6 Exec & VN V6 Exec
    May 2004
    Mornington Peninsula
    replace the globes & check the wiring, if the spoiler light is working the switch side is ok...
  18. #18
    eXcon's Avatar
    Aug 2006
    Gold Coast
    k checked the switch which as I said earlier fixed cruise and trac, gave the drivers side taily a tap and sure enough, bang, she came on , checked the globe that I didnt check before and sure enough, blown out. Grabbed a new one for 2 bucks at cheapa auto spares in oxenford, sunday arv just after midday, gotta love that, seems the connection is a little perhaps rusted or needs some loosening, but for the most part the car is up, running and fully functional, just the way I like it. Thanks for all the comments, I'm gonna write up a guide for this even though its covered loosley throughout the forums.
    Cheers! It's a load off.
  19. #19
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    Quote Originally Posted by eXcon View Post
    argh... cause your nearly on the rev limiter
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
  20. #20
    VYClubby's Avatar
    VYClubby is offline Proud Clubby Owner
    294rwkw Oztrack Tuned 220 cam
    Nov 2006
    Maybe the faulty brake light switch will fix the supercharger too! Seeing as it fixed the cruise control, and traction control! I never knew that little switch was so critical to how a car runs!
  21. #21
    eXcon's Avatar
    Aug 2006
    Gold Coast
    lol update, too the car to a mate who found a leaky hose at the rear of the supercharger, car now runs better than when I bought it...ROFL.
    I'll put that guide up in the Tute section asap.
  22. #22
    Flat_White is offline Banned
    Rolls Royce "Fantom"
    Apr 2008
  23. #23
    VY S L67
    Nov 2007
    execs were never factory supercharged? by the pic it looks like a vy ss or vy s with ss lights....
  1. VX SS starts but dies
    By vn88 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-05-2009, 04:19 PM
  2. vs v6 just dies
    By mahooody in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-05-2007, 06:54 PM
  3. car just dies wen im driving
    By Cozza88 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-07-2006, 11:09 PM
  4. VP just dies then goes
    By jiml in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-02-2005, 11:52 PM
  5. Vh 3.3 Just Dies
    By wreck in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 27-01-2004, 10:24 PM
