Register - Members List - Calendar - Mark Forums Read -
Go Back   Just Commodores > Holden Commodore Related > VY Holden Commodore (2002 - 2004)
VY Holden Commodore (2002 - 2004) Talk about anything relating to the VY Holden Commodore.
Reply
LinkBack Thread Tools Display Modes
  #1
Old 07-04-2008, 08:46 PM
guyman's Avatar
Ride: 03 VY_S
Trade Rating: (0)
guyman Executive
Default parker light
hey guys
when i switch on my parker lights only one works, however if i go and tap very gently (doesnt have to be hard) the one that doesnt work will come on and stay on untill i switch of the car, then when i start the car again it will not work, but at times it surprises me and magically works!(unlikely though). Iv tried replacing the globe and the thing the globe in connected onto (as i have a second pair of lights). Also tried to remove the little ring of rubber around the thing the globe is connected onto in an effort to get a better connection with the front of the enclosure but no luck there either. its not that much of a big deal but it is annoying. Im guessing there could be something wrong with the actuall headlight enclosure. The are second hand genuine SS lights.
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Google Bookmark this Post!Yahoo Bookmark this Post!Bookmark to AskJeeves!Bookmark to Slashdot!Live Bookmark this Post!Spurl this Post!Reddit! Wong this Post!
Sponsored Links
  #2
Old 08-04-2008, 07:13 PM
Calaber's Avatar
Contributing member
Ride: VY II BERLINA
Calaber Berlina
Either the globe is not seating firmly in the socket, or the socket has minor corrosion in it which prevents the contact until you tap it. Remove the globe, check it for signs of corrosion on the sides and on the base contact. Check the condition of the socket, clean out any corrosion you find, spray the socket with WD 40 to assist in the cleaning and removal of crap, then re-insert globe. This should do the trick.
Regards
pj
  #3
Old 08-04-2008, 07:28 PM
KRUPTD's Avatar
VN BT1 5L
Ride: VN BT1 5L,5spd,LSD
Trade Rating: (0)
KRUPTD Berlina
Very common on majority of cars,just replace the globe,the fillement insidethe globe is brittle/broken and once you tap the headlight lense it makes a contact which then makes the globe work.
__________________
(KRUPTOR)VN BT1 5L TTB's,MANUAL,LSD
  #4
Old 08-04-2008, 09:05 PM
guyman's Avatar
Ride: 03 VY_S
Trade Rating: (0)
guyman Executive
thanks for your help guys, dont have time this week to try and fix it but i shall attempt to do so on the weekend. Do u know where u could buy white l.e.d globes for the parkers not on ebay though. would my local autobarn stock them?
  #5
Old 08-04-2008, 09:34 PM
Calaber's Avatar
Contributing member
Ride: VY II BERLINA
Calaber Berlina
Can't help with that one. I've never bothered with the LED craze, but I assume they would need a new socket fitting to be used to replace the existing globe socket. No idea where to go for them.
  #6
Old 08-04-2008, 09:45 PM
Banks's Avatar
The change starts NOW!
Ride: VZ SSZ Ute
Banks Statesman
Quote:
Autobarn should have em, just remember you cant get any colour other then white. failing that i can get you some
__________________
VZ SSZ- LS1
I'd like to see you play the same shot again nicko! lol
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Thread Thread Starter Forum Replies Last Post
What bulbs does the VZ PArker Take Andre's SS VZ Holden Commodore (2004 - 2006) 1 05-07-2006 07:04 PM
Parker Globes.. Grommitt VR - VS Holden Commodore (1993 - 1997) 2 18-04-2006 03:43 PM
buzzing parker relay-Help chevy_big_block_bro Electrical Wiring / Questions 3 31-12-2005 08:47 AM
how to take parker bulbs out vg_ute VN - VP Holden Commodore (1988 - 1993) 1 16-10-2005 06:40 PM
Parker lights AttaBoy VR - VS Holden Commodore (1993 - 1997) 10 06-09-2005 08:47 PM
Credit Report | Credit Cards | Xbox Mod Chips | Mortgage Loans | Loan | Car Reviews
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
