Results 1 to 9 of 9
Thread: Drive belt noise after new pulleys
    VY 03
    Aug 2005
    Default Drive belt noise after new pulleys
    Just a quick question. Ive changed the 3 pulleys well 2 had to put 1 back on as the guy give me a different sized one. Ive had to spray the belt 2x as it makes a squealing sound the belts on properly could it be because of the new pulleys ? or have i done something wrong some how. Its the 2 tensioners and 1 idler
    rch-13z's Avatar
    rch-13z is offline im rick james..... bitch!
    VT Exec
    Jan 2008
    South-West Sydney
    my MRS car did that after it come back from the machanics last time..
    It was just a loose belt... does it do that all the time? or just at certain times like when you turn it on?
    Ado's Avatar
    Ado
    Ado is offline Are we there yet?
    vsII statesman L67
    Apr 2008
    hN,
    if its a belt squeal i have 2 tricks of mine which rarely fail. 1st one is quick and easy but u have to be careful. Everybody will tell u to lube it spray it and god knows wot else, very simple using the longest stretch of the belt between pulleys just gently rub the coarsest bit of sandpaper u have on the ribbed side of the belt (be careful thats why i say longest stretch between pulleys) for about 2-3 seconds basically all ur trying to do is curl the belt at each side. this should work for both accessory and supercharger belt
    If this does not work swap the direction of the belts in other words if u can read the part no. on the belt turn it round so ur reading the part no.s backwards let me know how u go
    VY 03
    Aug 2005
    Thanks for tip. Ill try the sand paper trick, it only takes me 7mins to get to work plus i wont be driving it other then that. And im doing the 3rd pulley on sat when i get the correct one. Oh and it only goes say about 5 mins after i spray it not when i start. Ill let you know how i go.
    adamc11 is offline Donating Member
    VY SS
    Feb 2008
    E. & W. Suburbs Melbourne
    Some squeeking can be normal if the belts have just been changed, as they take a little while to break in. What you can try doing is getting a hose and spraying water onto the belts while they are moving, and see if that fixes thet problem temporarily. If so, the belts could use come lubing or they may be a bit lose and may be slipping.
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    make sure the belt is located on the pulleys properly, ie all the grooves line up and the belt isnt sitting to one side
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    VY 03
    Aug 2005
    Ive check that and im sure there all on. Doing last pulley on sat will let yous know what happens.
    VY S Sedan
    Sep 2007
    If the noise wasn't there before you changed the pulleys,the chances are you have reversed the belt direction after refitting it.Remove it and turn it around and try that before you do anything.
    VY 03
    Aug 2005
    Ok I did the last pulley today The belt is on the correct way, gave it a boot full on the way home and no noise Thanks for your tips
  1. Drive belt ?
    By BLACK-2002 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-10-2007, 09:38 AM
  2. Drive belt gone?
    By gyp23 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-06-2006, 11:05 AM
  3. Drive belt won't stay on?????
    By blu278931 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-04-2006, 10:30 PM
  4. New Drive Belt Noise
    By drob1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-07-2005, 09:28 PM
  5. How to put the drive belt back on
    By sk1p in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-02-2005, 07:52 PM
