Results 1 to 15 of 15
Thread: VY Berlina Interior light flashes when door is open
    VY Berlina
    Apr 2008
    Unhappy VY Berlina Interior light flashes when door is open
    This is a small but ******* annoying problem with my VY berlina.
    When the interior light is on door mode, instead of the light turning on when a door is opened, it flashes on and off. I can hear a ticking noise like a relay coming from under the dash in time with the flashing.
    It's a standard berlina light and I have tried swapping relays and changing settings with no luck. I was at a dealer recently and they checked it out but couldn't figure out what it was.
    I've had to just switch it off but would be great if someone knew how to fix it.
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum
    CG Captiva SX
    Nov 2007
    Lower Hunter Region NSW
    I think there might be an option on the computer but I can't be sure. Check the owner's handbook to see if there are any options for the interior lights, and if so, go through the variations to see if that helps.
    VY Berlina
    Apr 2008
    I went through all settings in the computer for the lights but no joy. the handbook just says to go through the settings in the computer.
    I think its a fault because who would ever want the lights to flash when you open the door. the only time i could see that happening is if the alarm was activated.
    VY Berlina
    Apr 2008
    Calaber's Avatar
    CG Captiva SX
    Nov 2007
    This will sound dumb, but have you tried fitting another globe and looking at the contacts within the light? It might be that a poor contact, dirt or corrosion is causing some form of interference, overloading the circuit and causing a relay to cut in and out.
    Just a thought, but easy to check.
    VY Berlina
    Apr 2008
    Calaber's Avatar
    CG Captiva SX
    Nov 2007
    VY Berlina
    Apr 2008
    Well I pulled the light fitting out, swapped the globes over, made sure everything was connecting properly and nothing was shorting out but its still flashing.
    I traced the ticking sound back to the grey box under the dash above the pedals. Don't know what that is but it doesn't look cheap to replace.
    (Did have..) VSII Exec V6 A4
    Sep 2004
    Have you tried opening a different door to test the light? The switch that senses the door opeing might be busted... I remember something like this on my VS.
    VY Berlina
    Apr 2008
    Thanks John. It happens when any door is opened. I checked the terminals on the drivers door for corrosion or obstruction but it was fine.
    andyman's Avatar
    andyman is offline The Only 6sp VZ Wagon
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    Mar 2005
    Nowra, NSW
    Quote Originally Posted by MadDawg View Post
    that would be the body control module, is the flashing at a consistant rate or does it vary?
    EASTERN CREEK JCNSW 2009
    Quote Originally Posted by Commydoor
    First of all your words cannot harm me cause my ego is like a shield of steel.
    VY Berlina
    Apr 2008
    Yea, it def'ly flashes at a consistent rate. I think the BCM is the source of my problem.
    Are there any problems with just swapping it over? If not I might try the wreckers.
    andyman's Avatar
    Mar 2005
    Nowra, NSW
    if you swap it over you will need the key heads, and a tow to holden to have the bcm and pcm linked because of the vats systems,
    also if you buy 1, make sure it is the correct level ie 1 = exec, s, aclaim, ss, 2 = berlina calais 3 = stato, i believe
    VY Berlina - had VS Exec, VP Berlina LE, Turbo VL
    Dec 2005
    Blue Mountains NSW
    I had a problem with my interior light staying on continuously. Local mechanic knew what the problem was... Cables are too short inside the headlining so they rub, cut through and then earth out - light stays on.
  15. #15
    VY Executive
    May 2008
    Cattai
    I had the same issue with my old 1988 prelude. I replaced the interior light relay. That fixed it for me.
  1. Dome light not working with open door
    By Spyper in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-03-2006, 09:07 PM
  2. cant open any other door except for drivers side!!! (VP Berlina)
    By brey9186 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-03-2006, 06:24 PM
  3. Interior light/Door switch..
    By Parra in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-10-2005, 07:26 AM
  4. Berlina interior door trims...
    By VL Soldier in forum VL Holden Commodore (1986 - 1988)
    Last Post: 23-08-2005, 12:38 PM
  5. Hazard Light Button - Flashes
    By Sammy in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 15-07-2005, 03:36 PM
