Results 1 to 7 of 7
Thread: speedo calibration
    one_and_only2004's Avatar
    one_and_only2004 is offline Turbo L98 FTW
    Z Series Thunder Utility - Turbo
    Mar 2008
    Regional NSW Australia
    Default speedo calibration
    hi all,
    just throwing a set of 19" rims on the ute. where abouts would i go to get the speedo calibrated so that it reads correctly?
    Doctor Bob's Avatar
    Doctor Bob is offline Grandpa
    VT V6 Exec & VN V6 Exec
    May 2004
    Mornington Peninsula
    go to a holden dealer or someone with a scantool that can program the instrument cluster with the correct PPK value.
    Mar 2008
    COMMODORE EXEC VY
    Sep 2007
    VN Calais 5.0L
    Feb 2006
    you shoulnt need to change anything as the overall diameter of the low profile tyre will be pretty similar to what you have now.
    Mar 2008
    there's a fair difference between the two i've noticed. better safe than suspended...
    ve ss
    May 2009
    here are some suggestions
    go to dealer and check ppk setting to tyre size and get programmed or go to
    Tire Size Calculator - tire & wheel plus sizing which can be handy
    or when changing diff ratio formula is
    OLDPPK/OLDRATIO=A
    A*NEWRATIO=NEWPPK
    to be programmed with tech2 from holden dealer
  1. speedo calibration
    By 2wild4u in forum Holden Commodore How-To's
    Last Post: 05-10-2008, 03:59 PM
  2. Speedo Calibration questions....
    By Cobez in forum Electrical Wiring / Questions
    Last Post: 01-02-2008, 10:25 AM
  3. speedo calibration
    By shumway in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-02-2007, 08:19 PM
  4. speedo calibration
    By tbblitz in forum General
    Last Post: 04-09-2006, 01:33 PM
  5. Speedo Re-calibration
    By ozute in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-08-2005, 07:57 AM
