Results 1 to 6 of 6
Thread: S pac ute LSD
    one_and_only2004's Avatar
    one_and_only2004 is offline Turbo L98 FTW
    Z Series Thunder Utility - Turbo
    Mar 2008
    Regional NSW Australia
    Default S pac ute LSD
    is it normal for a ute equipped with an lsd to only have one wheel spinning? mine does it all the time - usually ending with me getting bogged out the front of work
    JD
    JD is offline Donating Member
    VS Berlina
    Aug 2006
    Deep South, SA
    either you LSD is worn out or maybe someone changed it to a single?
    We got rep back, yaaay!
    nicko's Avatar
    nicko is offline Carbon Positive - DO IT!!
    75 cruiser ute
    Sep 2007
    sa
    Jack the back end out the car up so both wheels are off the ground. Spin one of the wheels, if the other wheel spins in the same direction you have a LSD. If the other wheel spins in the opposite direction then you have a single legger. Also if you have a LSD it should have a tag on the diff that says something like "use only high performance lsd oil"
    no longer a hoon by association - the commodore is gone
    Mar 2008
    It is an LSD, she's got LSD stamped on it, and both wheels spin the same way. i just find it funny that only one wheel spins when it was sitting on the hill
    sp001in's Avatar
    sp001in is offline vyma100
    MALOO R6
    Jul 2005
    QLD
    my ute is an lsd v6 too, and i get the same problem.
    Check out my build <---Click me
    Now sporting ASR audio interior lighting and stereo mods, and MACE induction mods.
    Need your computer tuned, or dash calibrated??? Want your PS3 fixed, or wish to prevent the YLOD?
    nicko's Avatar
    75 cruiser ute
    Sep 2007
    sa
    The standard holden LSD is not all that flash. You can have them tightened though so they will spin two more often. Doesnt cost all that much just give a diff shop a call
