Results 1 to 8 of 8
Thread: Vy Front End Clunk
    10 VE SSV,03 VY Exec, 83 Wb Statesman
    Aug 2005
    Default Vy Front End Clunk
    radious rod bushes changed
    stabiliser bar and bushes changed
    front end still clunks, and ideas ?
    VT II exec wagon VX SS wheels
    Jul 2006
    Central Coast NSW
    fu2's Avatar
    fu2
    fu2 is offline The Man With No Name
    VP Berlina II - MY10 VE SV6 Ute - VH SL/E
    Jul 2004
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    He has already replaced them, stabilizer bar and sway bar are the same thing.
    Check the strut top mounts. Watch the top nut with the bonnet open and push the front of the car down, does that nut move? Put your finger on it as you bounce the car, you will feel it if they are buggered.
    Visit my Facebook page
    Aug 2005
    well somone had put the strut top mounts upside down we put the the right way around but she still clunks
    vy ss commodore 5.7ltr
    Jul 2006
    i have the same thing on mine, changed my tie rod ends, was a quiet but its slowly come back,alot better than it was though, and iv got the same clunk noise in the rear, my tie rod ends were ***d though, but still there a tiny bit only every now and then from the front, but still there all the time from the rear
    VY S2 Crewman
    Apr 2006
    I had a recurring clunk in the Crewman and after changing the usual bushes, they ended up changing the rack and pinion (under warranty) - but not the tie rod ends. No more clunk......................
    Jul 2006
    yeh that or struts was my next option, but after changing the tie rod ends the noise is alot quieter than it was and the steering alot better, but still there a tiny bit, so might be in the rack as its very quiet now, i tried to get the rack replaced under the extended warranty iv got with nation wide, but they wont do it unless an internal seal is leaking, so couldn't get it done under warranty, so see what happens.
  1. Clunk in the front end of VS wagon
    By Old Colts in Oz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-09-2008, 02:45 PM
  2. That Front End Clunk
    By Caz_88 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 04-12-2007, 12:28 PM
  3. every bump hit the front end goes clunk
    By hsv14u in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-08-2006, 05:04 AM
  4. That Front End Clunk
    By Caz_88 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 23-06-2006, 08:25 PM
  5. VT(S) Front End Clunk!!!
    By Happy Panda's in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-08-2005, 09:48 AM
