Hey does anyone know if a level 3 gauge cluster will fit a Series1 VY S and if everything will work correctly?![]()
isnt this a question for the vy section?
yes it will but it will need to be programmed to suit your car, the only thing to watch is make sure you have the same series as some have a different fuel guage setup & will work backwards.
this can be corrected with some custom programming but it can be costly (about $180)
Rob
it was moved to the vy section, was originally done in the v6 section.
dont worry everyone does that every once in a while :P
I hope you paid attention to what Dr Rob said.
Be very, very careful that you get the correct cluster for your model. Make sure that it is a VY Series 1 cluster, not a Series 2.
It will save a lot of hassles down the track.
I put a caprice instrumentation in mine, just make sure it has a grey plug on the back. everything can be programmed by your holden. If the milage is over 100,000k's, places like namiis(www.namiis.com.au) can reprogramme the mileage for about $130.
