+ Reply to Thread
Results 1 to 11 of 11
Thread: VY Calais Fog Light bulb change
    VYII Calais
    Apr 2008
    Default VY Calais Fog Light bulb change
    Does anyone know how to change the right Fog light globe, on VY11 calais, service manual says send it to the dealer, Max Ellery's not to helpful. I stuck my head under there and I don't know.
    Lumps of cheese's Avatar
    Lumps of cheese is offline catch us if you can Lumps of cheese ClubSport Lumps of cheese ClubSport
    MY08.5 VE V8 CALAIS/2010 Hilux SR D4 Dual cab 4x4
    Boulder Crusher Champion! Balloon Park Champion! Action Fish Champion! 501 Darts Champion! Frogger Champion! Jungle Kid Champion!
    Nov 2005
    Warrnambool
    gottavecalaisv's Avatar
    gottavecalaisv is offline Calais' are great mate! gottavecalaisv Berlina
    Ve Calais V V6
    Jan 2007
    The plastic light surround removes by squeezing it pretty hard as it has tabs that go under the trim surrounding it. Then just undo one screw from the chrome bezel surrounding the fog light and it comes out easily. While it is out consider putting in HID as i did, WOW what a difference and a much whiter light too.
    Good Luck.
    VYII Calais
    Apr 2008
    Thanks guys. I think it might not be that simple, it looks like the whole air intake grill on the bottom has to come off, before I can get at it.
    thanks anyway DD calias
    Ve Calais V V6
    Jan 2007
    VYII Calais
    Apr 2008
    Sorry Gottavycalais. Looks like the front bumper needs to come off (at least the right side) according to the Techs?? at Holden, booked in. about 30$ including bulb.
    Ve Calais V V6
    Jan 2007
    i think you are being taken for a ride. just squeeze the chrome bezel and then undo 1 screw and its off! easy as pie!
    VYII Calais
    Apr 2008
    Just had another look at it. The Chrome bezel is glued to the lower grill. it is all one.
    Ve Calais V V6
    Jan 2007
    ok maybe a series 2 calais is different to a series 1 in the front fog light area? sorry for the confusion. $30.00 is cheap but the front bumper is only held on with 7 screws so maybe do it yourself? good luck whatever you decide
    VYII Calais
    Apr 2008
    Calaber's Avatar
    Calaber is offline Nil Bastardo Carborundum Calaber W427 Calaber W427 Calaber W427 Calaber W427 Calaber W427
    VY II BERLINA
    Nov 2007
    LOwer Hunter Region NSW
    Quote Originally Posted by gottavycalais View Post
    My VY 2 Berlina was fitted standrad with VY 1 Calais lower bumper insert and fogs. I'll check out if I can do what you suggest over the next day or so. I suspect the VY 2 lower grille might be a one piecer.
+ Reply to Thread
  1. Level 3 cluster bulb change.
    By VS_Pete_1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-04-2008, 01:23 PM
  2. How to change the centre consol light bulb
    By ozengines in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-09-2007, 11:48 PM
  3. 'Rear light bulb failure' warning light
    By Misaprop in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 22-04-2006, 02:07 PM
  4. Replies: 6
    Last Post: 17-11-2004, 10:58 PM
  5. light bulb for speedo
    By fergi in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-11-2004, 04:57 PM
