Results 1 to 7 of 7
Thread: Engine Rev / Speed
    COMMODORE EXEC VY
    Sep 2007
    Unhappy Engine Rev / Speed
    Driving normaly engine rev stay abt 1500 at 60KMH
    but some times engine revs go on to 2300+ at 60KMH and engine makes loud noise more than normal. Specially accelerating from 0 KMH on wards it makes some strange niose, react slow in response to no of revs.
    Restart the car and it gets normal. Normally happens on long drives.
    its a VY exec sedan 2003. it has done more than 224,000+.
    i bought it a year ago at 200,900. It is and was very well maintained and clean car inside out.
    i dont know much abt cars so can any one advice what needs to be replaced after these many Ks*(differential, timing chain, exhaust etc), because it feels slow and loud and even more louder when the above mentioned problem kicks in.
    vnv8driver is offline Banned
    304 Calais
    Aug 2007
    Up your mum
    sounds like a normal commodore to me, sounds like the transmission is in third gear if its sitting on 2300rom @ 60km/h, is the automatic fluid topped up?
    COMMODORE EXEC VY
    Sep 2007
    ya fluid is all good
    feels like when u drive a manual and push the clutch half way and accelerator as well, car moves but dosent move as fast as with out the clutch.
    cant even show that to machenics, because it dosent happen evey day.
    VY Acclaim S2
    Jan 2008
    Quote Originally Posted by Lafanter View Post
    This sounds a bit like a problem I had with my VR. Turned out a bearing was sometimes popping out of place and stopping the gearbox from selecting first and it would stay in third. So needless to say when you took off she would rev her box off and move VERY slowly.
    It was annoying because I couldnt say when it would happen so it was hard to demonstrate the problem to a mechanic, although it was more likely to do it on long trips. If I had left it, the bearing would have eventually worn through the outer casing and cooked the gearbox.
    I had to take it to an automatic transmission specialist who fixed it for around $550. Certainly cheaper than a new gearbox!
    Shounak's Avatar
    Shounak is offline The Kicking Horse
    VX Executive S2 + XF Panel Van Project
    Apr 2005
    You could probably have bought a tranny from the wreckers for a few hundred and had it whacked in either by yourself or the wrecker for less.
    Changeover anything for Commodores is not usually very expensive.
    Shounak
    Always Right
    My Ride
    VY Acclaim S2
    Jan 2008
    Oh well. Dont have the car anymore and hopefully wont encounter that problem again.
    COMMODORE EXEC VY
    Sep 2007
    Quote Originally Posted by scottifa View Post
    thanx for pointing this out
    my cars is under warranty lets see what they say?
  1. (S.A.) F/S : Gen3 Engine, 6 speed, full conversion
    By g00gz in forum Parts And Other Items For Sale
    Last Post: 08-04-2008, 10:47 PM
  2. engine speed in VZ
    By davesv6 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 25-11-2007, 05:07 PM
  3. blue 253 4 speed manuel swap for 3 speed trimatic and 202
    By quick202 in forum Swap / Wanted to Buy / Trade
    Last Post: 05-10-2005, 11:12 PM
  4. blue 253 4 speed manuel swap for 3 speed trimatic and 202
    Last Post: 05-10-2005, 11:01 PM
  5. digital speed read out in VS with speed alert
    By vs0001 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-06-2005, 06:09 AM
